Steering Vibration
djcormie Apr 28, 2008
  1. djcormie
    djcormie Member
    42
    Hello All, need some advice
    My 2000 S6 has a slight vibration through the steering wheel when on full lock at slow speed, when turning right, theres also a faint squeakin noise. It doesn't shudder under braking and theres no noticeable vibration at speed. I had the wheels rotated and balanced over the weekend and there's was no play from the wheels when they were off the ground.
    Any ideas before I head off to the garage, just worried they'll take the piss once they hear S6
    Mark
  2. djcormie
    djcormie Member
    42
    any ideas folks
    Mark
  3. fjtwelve
    fjtwelve Moderator Staff Member Moderator
    770
    10
    CV joint failure tends to be more a knocking /cracking noise than a squeak. Wheel bearing may be on the way, if its getting serious you would start to notice the steering becoming slightly less precise at speed. Suspension arm bushes classic weak spot, these do make strange noises. Power steering fluid level worth checking, if its low, at full lock the pump may be squeaking as it cavitates through lack of fluid, and pulsing/juddering as it pumps then doesn't.
  4. djcormie
    djcormie Member
    42
    thanks for the reply fjtwelve, I had a response on rs246 for the wheel bearings, so thats a thought, but I have noticed that it will vibrate slightly when on full lock to the left, definitely not as much as turning right but its still there. MUst have a look at the fluid level myself to see
    Mark
  5. SiliconS
    SiliconS Member
    92
    I'd guess power steering too... (But I'm no expert. :) )
