Steering started feeling vague after pothole
JD09 May 8, 2010
  1. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Any ideas on this? Had a quick search and looks like the steering rack on the S3 is not the greatest. My Clio's rack went and it felt a hell of a lot worse than this. When driving around the car park (smooth surface, low speed) it is find and perfectly responsive. But when going over bad road surfaces, it feels like the steering wheel isn't well connected . . . ??
    My tracking is currently out, so getting it booked . . . is it worth asking JBS to have a look at it once its up on the alignment machine? Are they likely to be able to tell/check anything?
    Many thanks!
  2. Broken Byzan
    13,237
    465
    Snapped spring i recon, looked at one for a friend this morning, same symptoms. Was able to pull the broken section out and hand it to them,lol
  3. JD09
    3,096
    46
    Ah christ. Would that cause the symptoms above then Byzan?
  4. ALPINE
    3,093
    jd mine does that and it irritates the fk out of me.. and i have replaced everything. only thing i have`t is my tie rods. (i have changed the ends.
    could also be what mark says tho. question do you have a little clonk noise when stationaray and you move the steering wheel quickly from side to side. (like a little wiggle)
    EDIT: i have not replaced my ARB just the bushes.
  5. JD09
    3,096
    46
    :( yes fella, a slight clonk (not audible, just feel it through the wheel).
  6. ALPINE
    3,093
    yep, thats what i have mate. i dont know what it is. winds me up daily!
  7. vetch
    vetch S3
    430
    Ive got that very same clonk when turning the wheel when stationary, Ive bought a new steering rack and Im hoping that sorts it.
  8. JD09
    3,096
    46
    Gay. Can't believe this. The one thing that really made me sell the Clio was the steering issue. At least this feels beefier than the Renault steering, so not going to bother me as much. Have to take it to be aligned soon at JBS so might get them to give it the once over and asl what can be done. Any suggestions on what else I can check tomorrow night by taking the wheels off? Presume track rods I can check with the old "hold the disk and wiggle it up and down and side to side" trick?
  9. ALPINE
    3,093
    how much did you pay fella? if i need a new rack i was going to get a S3 rack as i hear there quicker and will fit an A3 with minor adaptation.
  10. vetch
    vetch S3
    430
    When I say "new" rack, I meant newer than mine, but actually second hand. Buts its a low mileage one and in great nick. Got it off fleabay for £120 inc postage.
  11. sportquattro
    sportquattro Active Member
    834
    51
    I had similar problem, apart from bursting 2 tyres in last 3 months on potholes, found out this week i had a cracked rear ARB and sloppy trackrod end, all fixed now and car feels fine. What grips me is that we pay a friggin fortune in road tax and fuel duty but have to drive round on roads that end up wrecking our cars.
  12. JD09
    3,096
    46
    Mate, I've actively started searching out bad potholes recently. I now have damage to my car from one around my GFs house. So I am going to take a photo of one, send it off along with the engineer's report on the damage and tell them I expect something to be done about it. Not likely to get far, but meh, it solves my anger.
  13. ALPINE
    3,093
    good luck mate. i tryed that route when i hit my audi in a pot hole. They will send you a form the size of a house asking you for the inner diamiter of your arse hole. make sure the Pot hole has not got any council markings on it as this indcates they know about it. in which case you have no leg to stand on.
    Get pictures using a tape measure from all angles. pictures of the surroundings. they will want you to Draw out what happend as well. for this very reason, i could not be arsed!
  14. Y83OLK
    Y83OLK Hulk Smash!
    841
    Mine does this too JD.
    Im hoping its not the rack, possibly rack mounts?(are there any?)...steering column U/J?
  15. JD09
    3,096
    46
    God knows Callum. I am prepared to fill out that form to no end lad. They are sooo bad around me. I didn't even realise you could claim when I lost a tyre and wheel on my old car!
    Any other thoughts on what it could be?
  16. ALPINE
    3,093
    just as a help, i had this clonk before i replaced the following.
    Wishbones
    ball joints
    coilovers
    ARB bushes
    Tie rod ends
    front end wise thats it. still clonks!
    If i got full lock and get the missis to move the steering wheel, when touching the tie rod arms i feel the clonk. Everything else is tight as a nuns ....
    I changed my tie rod ends and its better than it was but still clonks.
  17. JD09
    3,096
    46
    Appreciate that lad. Will look into it next week.
  18. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    regarding the pot hole issues i have been paid out took 12 months photos needed and quotes for repair/replacement hassle forms but worth it
    steering rack.. mine is the same and needs replacing.. wiggle your steering wheel through your open drivers window and see the reaction of the drivers road wheel... any delay you have a problem... maybe ball joints but you would know that from other issues ...
  19. rossbrownlee
    rossbrownlee Ross_S4
    719
    What about replacing the track rod? There is also a ball joint at the inner end...
  20. ALPINE
    3,093
    thats my next move if im honest. just lack of funds atm. inner end ball joint?? pics?
  21. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    On a previous car I had a badly worn track rod end and I could feel the wheel moving about on its own. Braking at high speed was the worse.
    Could be something to look at as if that goes there will be alot of play around the hub which makes the steering wheel feel very loose
  22. ALPINE
    3,093
    i changed my track rod end about a week, 2 weeks ago, still have me clonk. It doesnt feel as bad tho.
    anyone got a front end diagram?? my moneys on my ARB as its the only thing i aint changed.
    EDIT: or the rack :(
  23. JD09
    3,096
    46
    What sort of pricing are the above Alpine? I'm going to take my wheels off tonight and wiggle the disks, see if there is any movement (showing trackrod ends if memory serves?).
  24. S3 Nattie
    1,599
    When my track rod end went you could move the wheel and hub and none of the suspension would move, can see the play in the bush. Have to jack it up though
    Was quite bad how much it moved. They are usually around £15 - 20 and very easy to change
  25. S3 Nattie
    1,599
    The track rod end will still serve/rotate a little as its on a ball. If it has play in the bush it will be forward and backwards.
  26. ALPINE
    3,093
    mine were about £7 each from Euros. before you jack it up, go full lock and get ya woman or ya mate to wiggle the steering wheel. get ya arm in the arch and touch everything. if you feel the clonking then you have a good idea where its comming from.
  27. JD09
    3,096
    46
    Cheers guys. Might have to be tomorrow night but will do
    It asap.
  28. rossbrownlee
    719
    Not a perfect match to what is on the S3 but close enough. The big bit on the left hand end of this track rod is the inner ball joint. It is normally covered by the gaiter.
  29. ALPINE
    3,093
    ahhhhh i see!! this has to be the culprit!! question is.. can these be replaced on the car or is it rack out bizzle?
  30. rossbrownlee
    719
    Wouldn't rule everything else out mate but it's a possibility...
    They are fairly cheap though, about 25 quid on fleabay. Never done one myself but by the looks of it should be pretty easy without removing the rack. Access might be a bit awkward but as long as you can reach the flats on the sliding section of the rack you are good.
  31. rossbrownlee
    719
    The S3 trackrod. Luckily my replacement rack came with them and ends. off a TT quattro too.
  32. ALPINE
    3,093
    i have replaced nearly everything else so theres not much to rule out! lol
    coolness.. ill get on the case! cheers matey
  33. Dani_B19
    9,047
    337
    Ive got the exact same thing but mines down to the fron head crash i had due to some stupid b*tch not been able to drive (Fking women).
  34. JD09
    3,096
    46
    OK, from driving home last night on the relatively smooth tarmac of the M6 motorway, for over an hour, I didn't feel the issues once!
    Once off the motorway, I felt it a couple of times but didn't notice any issues on my private race track, while doing 90+ (safely).
    So it would appear, if I go over a slight bump, it almost knocks the suspension up and the steering goes light . . . Gotta be wishbone related?
  35. ALPINE
    3,093
    my first thought were wish bones and they were the first thing i replaced. my simptoms are the same as yours mate. flat road its no problem. hit some bumpys and the steering feels like the wheels are about to fall off!!
