steering stalk controls a4
stuartyp Jun 17, 2013
  1. stuartyp
    stuartyp Member
    59
    i have a 2005 a4 and i am wanting to fit an alpine headunit. I would like to keep the steering controls my alpine has a 3 mm jack plug at the rear of it for them does anyone know the connects code for the product i need..
  2. NHN
    29,413
    1,740
    Steering controls go via the canbus system, I assume the jack plug is for an ir remote of some shape or form, you need a direct can connection to accept the steering controls unless alpine have a can to IR unit, which I doubt but hey.
    What model alpine is it?
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    is this the same sturtyp from t/a?
    if so im afraid your on a changover year mate so it could be either of these
    ctsd002 (2005 onwards) or ctsd003:2 (upto 2005) be carefull as some suppliers require you to buy a patch lead also
  4. stuartyp
    stuartyp Member
    59
    Yes mate that's me it's for my DVI9990r F1
  5. stuartyp
    stuartyp Member
    59
    mate it's a DVI9990r F1 unit. I have a friend that fitted one to his Astra and he used the 3mm plug at the rear of his and It works fine. So I'm wanting to compete next year so I'm looking into this.
  6. dualmono21
    1,138
    if you wanna pm me your reg buddy ill try and get the correct one for you tommorow
    nath
    i aint got steering controls in my car but if this is doable i may look into retrofitting them and putting them on my f1 for ease of use
  7. stuartyp
    stuartyp Member
    59
    It defo works mate. My reg is ky05xuh. Like I said a friend has done it and he said it goes into the 3mm jack on the back of the unit. So I hope it helps you.
  8. s8craig
    1,753
    56
    I had an Apline HU in an A3 8P with steering wheels controls, unfortunately the interfaces were just black boxes so I can't help you with options. But the system is sitting my mates A3 and works perfectly well.
  9. NHN
    29,413
    1,740
  10. stuartyp
    stuartyp Member
    59
    I think you can buy a patch lead that goes into the black box and turns out a jack plug.
  11. dualmono21
    1,138
    yes usally the patch leads are about £5 but depend on what make headunit your using
