Doesn't work on my 2011Does the below help?
Taken from http://uk-audis.net/topic/189-transform-your-a3-remap-your-steering-i-did/
- Click on '44-Steering assist'
- When you go into this module, it will scan for fault codes and go straight to a fault code screen. It should say 'No Fault Codes Found'. Click the 'Done, go back' button to get to the main screen for this module.
- Click on 'Adaptation - 10'
- Click on the 'Channel Number' "Up" Icon until it shows Channel 1
- Click the 'Up' or 'Dn' buttons to get to a new value, don't just type it in. People report liking '0' (least boost) through '3' as new settings, I personally prefer '2'.
- Click 'Save'
- It may ask "Are you sure", click "Yes"
- You may want to check again to make sure your new setting is showing up in the 'Stored Value' field, just to be sure.
- Click 'Done, go back'
- Click 'Close controller, Go Back'
Also, why did you raise a second thread on the same subject? >>>> http://www.audi-sport.net/xf/threads/steering-wheel-sensitivity-adjustment.251551/
