Steering noise??
Jonezy87 Sep 14, 2010
  1. Jonezy87
    Jonezy87 Member
    124
    When reversing out my drive, I have a wining noise from slight steering.
    Any ideas? Car is also lowered on coilovers
  2. Jonezy87
    Jonezy87 Member
    124
    Also I have checked the power steering level and seems ok
  3. Jonezy87
    Jonezy87 Member
    124
    anyone??
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Only in reverse? Never does it in forward drive?
  5. Jonezy87
    Jonezy87 Member
    124
    no it does in forward aswell only when goin slow? cheers for the reply
  6. Welly
    10,696
    129
    Sounds like a PAS issue. I would start with bleeding the PAS system, however I would expect it to be the PAS pump.
    Worth bleeding it just in case though - however it would normally bleed itself under use.
    Jack both front wheels up off the floor. Take the PAS res cap off. Check the fluid before hand.
    Turn the wheels from full lock to full lock about 10 times, and check for bubbles in the PAS reservoir.
    Shouldn't take more than half an hour at the VERY most - so worth a go.
    If not, I;d be looking at the PAS pump.
