Steering issue
Discussion in 'A4/A4 cabriolet/S4 forum(B6 chassis)' started by jibbajabba, Jun 20, 2007.
  1. jibbajabba
    jibbajabba Member
    Jun 18, 2007
    35
    Trying to source a problem with steering on my 1.9 TDi (non Quattro :-( ).
    Firstly, she pulls to the left, previous trip to dealer mentioned susp. arm needed, but another mechanic overruled at next service and said it was fine?
    Also, slight vibration in steering while driving, but here's the cruncher, once I hit say 75-80mph, that vibration increases where I can feel a physical knocking in the steering, so I am assuming vibration frequncy increases or something with speed.
    Could this be a trackign issue, or is my steering on the way out, i.e rack replacement.
    Anyone, experienced anything similar, or have any ideas
  2. Advert Guest Advertisement
  3. Nickynibbles
    Nickynibbles Damn it where's 7th gear when you need it?!
    Jun 5, 2007
    845
    Both pulling & vibration is more than likely a tracking issue, certainly the cheapest place to start! Other options would then be bearing, steering rack, suspension issues but as tracking is a double figure fix i'd start there!!
  4. jibbajabba
    jibbajabba Member
    Jun 18, 2007
    35
    Cool, will get the tracking looked at and see where that takes me...
  5. jibbajabba
    jibbajabba Member
    Jun 18, 2007
    35
    I doubt it is tracking after all. Just experienced the knocking through the steering wheel on a broken surface turning circle at low speed.
    Does this then point the finger at the column or something? Best way I can describe it is, as if there is play in whatever attaches the steering wheel to the front wheels, feels disconnected and rattles through the steering wheel.
  6. arthurfuxake
    Mar 16, 2004
    1,308
    CV joint?
  7. terrysingh
    terrysingh Member
    Mar 12, 2007
    184
    i used to get a knocking through the steering on some uneven roundabouts, ended up being the track rods, and upper arms, changed everything when i had the coilovers fitted, drive like a new car now,
    get the wheels off and have a good look around even a bit of play or ware can cause knocking.
  8. jibbajabba
    jibbajabba Member
    Jun 18, 2007
    35
    was hoping I wouldn't be going down this track with it.
    Upper arms, CV joints etc, are these dealer fixes or can an inexperienced mechanic (me) do the job with the right parts?
