Steering Assist in VAGCOM
metricspaces Nov 17, 2010
  1. metricspaces
    metricspaces Member
    661
    Anyone ever try adjusting steering assist in VAGCOM? Here's one guide:
    Steering Assist
    You can change how much input is needed on the wheel to turn it. It's set at 5 on the GLI.
    Select 44 (Steering Assist)
    --> 10 Adaptation
    Read channel 1.
    Lower numbers are harder steering, higher numbers are easier. Range is reported to be between 0 and 6.
    And some links...
  2. Mpathe
    Mpathe 1st gear
    394
    isnt this for the newer shape a3/s3
  3. metricspaces
    metricspaces Member
    661
    I don't know. All the pages I've read seem to refer to newer models. Does anyone know if the same works on the 8L?
  4. Mpathe
    Mpathe 1st gear
    394
    power steering one no as the 8L runs a belt driven pump so not adjustable, you can adjust certain things but not as many as newer models
  5. metricspaces
    metricspaces Member
    661
    Cheers for that :) !
