steering arm seized
dope Aug 16, 2012
  1. dope
    dope alcoholic pervert
    199
    Afternoon.
    Just had a couple of tyres put on the front and was going to get them to do the tracking (which is out by quite a bit on the nearside) but the guy said he couldn't undo the steering arm to do the adjustment.
    Any ideas? Am I on the cusp of a world of pain?
  2. marktdisport
    marktdisport Active Member
    1,195
    15
    Take it to someone with some knowledge m8... Just may need a bit of heat and a tap to free up
  3. dope
    199
    Worth giving it a try myself on the drive do you think, or will I do more harm than good?
  4. marktdisport
    1,195
    15
    Give it a try plenty of wd40 and maybe a bit of heat if it won't budge
  5. dope
    199
    Will do. Need to look see if a broken sensor wire is the reason the pad warning light is on, so I'll attack the arm at the same time.
  6. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    I got my B5 (and a few other cars) arms with a giant stilson and scaffold pole combo. I have oxy-acetlyne, but you have to be careful of rubber damage.
    I've also used a jack to turn the stilson on stubborn ones, but I'm rough!!
    It's that or take steroids :weight_lift2:
  7. marktdisport
    1,195
    15
    LOL!!!
  8. dope
    199
    Nice! Never underestimate the role of scaffolding in automotive repair.
  9. spartacus68
    spartacus68 Active Member
    156
    34
    ...or a sawn off exhaust pipe (Ray Winstone would be proud of me)! :yes:
  10. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    Heat worked on mine - same issue.
  11. EK
    EK New Member
    use some heat, put some wet cloth arond to protects the rugger gaitors
    It should free it
