Steel wheels and winter tyres
defer Nov 14, 2010
  1. defer
    defer Member
    87
    I've been offered some 17" steel wheels with winter tyres off a 2009 A4. Question is will they physically fit on my S3, will they alter the speedo reading and will they look naff. I want winter tyres as i found the S3 to be quite rubbish at stopping in the snow last year
  2. N8
    17,163
    718
    Not sure if the 345mm discs will clear the steelies, possibly.
  3. IanMcA3
    IanMcA3 Member
    59
    If they are off a B8 chassis car (which I assume the 2009 model will be) then the centre bore will also be 66.56mm vs the 57.1 of the 8P A3 - not a massive issue (set of spigot rings) but the offset may be too aggressive
    If you don't take them up - I will probably be interested as I need some winter tyres for my A5 :) - now that was sh1t last year - no quattro & 255 section tyres on a 9j rim :(
  4. defer
    defer Member
    87
    Thanks for the answers. I looked at them today and they're actually 16" not 17" so they're definately no good. IanMcA3 if your interested i can put you in touch, they are Nokian 205/55/16 M+S tyres. Quattro is good for setting off but i found stopping to be the hard part hence the search for winter tyres. I've found some Toyos for £128 each, Falkens for £115 each or Semperit for £154 each all in 225/40/18 92v, i used Semperit M+S when i was in Germany so i know they're good
