Steamy Windows!
Mazi Nov 2, 2013
  1. Mazi
    Mazi Member
    49
    My 2006 Avant seems to stream up a lot especially when I put the heaters on?
    Is this the blocked scuttle drains that are common on Passat and A4 causing the problem or something else?
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    have you replaced pollen filter? They get full of muck and damp as well and cause bad ventilation.
  3. Mazi
    Mazi Member
    49
    No sir but the car was serviced at Audi this year. Dont know if pollen filter is routine service item as it is with BMWs.
    Where is it located?
  4. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,516
    3,070
    it's in the plenum chamber, just to the right of the battery when looking from the front of the car. Just remove the plastic cover, pull the filter out and Bob's your uncle. Incidentally, even though they're not mega expensive, you might be able to clean it rather than buy a new one. I left mine soaking a bowl full of hot water and washing powder for a hour or so, then scrubbed it out with an old toothbrush.
  5. etxeondo
    etxeondo Member
    67
    Need to change mine myself, though what i tend to do after installing pollen filter is a bowl of uncooked rice left for 24 hours to absorb any remaining moisture inside your car either passenger or driver side. Make sure when seating the pollen cover back on it is properly seated as moisture will come in.
    As mentioned there not expensive, depending on if you want paper or charcoal filter the price varies.
    If you use glass cleaner and polish stops the misting a good bit i found.
  6. Mazi
    Mazi Member
    49
    My mate said I need to clean the scuttle drains also as these can be a problem on VAGs of this era.
    I might as well do that at the same time
    Do we have guide on the forum anywhere?
  7. hades-
    9,482
    646
    easy job remove battery and remove the 2 gromets
    job done
  8. etxeondo
    etxeondo Member
    67
    is the battery not bolted in with a torx on the battery bracket clamp, im near sure it is?
  9. jdp1962
    8,516
    3,070
    Yes it is.
