steamy windows
rOb_A Oct 10, 2011
  1. rOb_A
    rOb_A Active Member
    1,488
    not posted for a bit so here goes... but before you reply no cheeky responses ( as i know i would) :nunu:
    noticed my windows are steaming up, where i have put the screen clear on quite a lot. any ideas why this happening and how to stop it???
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    is any of the carpets damp?
    does the air smell of coolant?
  3. rOb_A
    rOb_A Active Member
    1,488
    nope carpets are fine, no coolant odours. its seems to happening on damp/wet days. its a proper pain. any other ideas??
  4. ScottD3
    15,165
    1,124
    water leak or coolant ingress.
    Only ideas I got.
    Its trying to find it.
    I use to get this issue in the back of my Avant.
    I had 2 rubber gromits missing from the boot area.
    I replaced theses put in some of them bags you get with IT kit to help stop the moisture and it helped.
  5. rOb_A
    rOb_A Active Member
    1,488
    thanks Scott, will have a good look around the car over the weekend to see if anything is missing
  6. Farhan
    Farhan Active Member
    1,234
    58
    you may need to find a local holiday inn or a cheap B&B to stop this problem if you are making use of the extra doors on the sportback
  7. ScottD3
    15,165
    1,124
    Sportback?
    You mean the A3 Avant?
  8. vw754
    vw754 vorsprung Durch Technik
    2,351
    58
    Try changing the pollen filter.......it usually helps a very lot ! are you noticing a smell which lasts for a second or 2 just as you start the blowers?
  9. rOb_A
    rOb_A Active Member
    1,488
    my A3 avant was serviced only 2k ago, so would have thought the pollen filter was changed then, but will check it out.
    holiday inn??? i'm more a hilton man myself :p
  10. Farhan
    1,234
    58
    ooooh classy :cool:
  11. Ash187
    7,520
    758
    maybe take your car to a polish man and get him to wash it inside and out... do the windows... usually a £10 job... seemed to work on my A3 Avant :)
  12. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,382
    214
    Fit double glazing, works for me :)
  13. A1DEYB
    A1DEYB Well-Known Member
    1,681
    43
    Shouldn't happen if you have the climate control on, mines on all the time and my car never steams up as the AC takes the moisture out of the air.
  14. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Moderator
    5,920
    30
    Oooohhh mine steam up at the weekends!!! lol!
    seriously, maybe the inside of the glass needs a good clean.
  15. jamessg1962
    jamessg1962 Member
    123
    Had the same problem, and like Aiden has said it was because my air-con was knackered.
    If the air-con is working properly and not in Econ mode you shouldn't get steamy windows.
  16. rOb_A
    rOb_A Active Member
    1,488
    will get the ac on, need to check out the pollen filter, are hard to fit?
