Steamy Headlights
Boydie Jan 30, 2007
  1. Boydie
    Boydie Guest
    Can steamy headlights be replaced under warrenty?
    just noticed last night when washing the car the the lights steemed up :think:
    thanks guys
  2. Covenant
    Covenant Member
    246
    Sounds like the rear cover hasn't been replaced properly. With the cover in place the headlamps should be watertight and therefore not let dampness in to cause the problem.
    I doubt you will get a warranty replacement unless there is a physical defect causing the unit to allow water ingress.
  3. alanjonesbath
    alanjonesbath VAGOwners.co.uk
    188
    In a word, no, unless there is actually water inside rather than a small amount of misting. Its actually mentioned in the manual that some misting can occur on the headlight lens, and should clear after the lights have been on for a little while.
  4. cliveywolves
    cliveywolves Member
    229
    i get a little misting sometimes on one of my headlights also , nothing major just a little niggle to live with , but does clear quickly....
  5. steve184
    steve184 Active Member
    1,138
    i used to get a bit on my drivers headlight too - it seemed to come and go... and come again...
  6. Boydie
    Boydie Guest
    ok thats fine - ill check round the headlight later today to see if there is any cracks or leaks
    thanks for the info guys :D
