Stealer Wheel alignment print out - your thoughs - PS i paid £165 for this RESULT
benelton Jan 11, 2013
  1. benelton
    benelton New Member
    Stealer Wheel alignment print out - your thoughs - PS i paid £165 for this end result
    My thoughs are the rear should have been adjusted better than this, particularly the rear camber...
  2. NHN
    29,423
    1,740
    If you're not happy, why didnt you ask them to adjust it better whilst there, as they would of handed you the slip at same time, also £165, damn what they use for that price.
  3. Boon
    Boon Active Member
    441
    59
    You would think they'd be able to afford a new ink cartridge at that price :blink:
    Sidhu88 and RedDejavu like this.
  4. NHN
    29,423
    1,740
    lol, so true, looks like heads need cleaning.
  5. Ash187
    7,496
    744
  6. sportstractor
    sportstractor Chugger
    2,709
    My dealer quoted around the same to align my old 8L S3. I ended up speaking to one of their tech's who told me who they used to do all there alignment work, and went directly to them, virtually cutting the bill in half.
    Rear camber is way out, not sure what adjustment there is for that. Is it a quattro?
  7. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    was just about to say that:D. First thought:D
  8. martinivw
    martinivw :)
    446
    24
    The rear camber can be adjusted very easily by the cam bolts (1 on each side) I'm sure I posted a pic of rear axle a while back somewhere......
    Ta Da
  9. benelton
    benelton New Member
    Yes my main disappointment is the print out, fancy robbing me of the satisfaction of consistent ink quality on the report.....
    well it turnout I got this free gratis anyway. I have some other work done and when I checked the invoices they forget to charge my card for the 165 which was on a separate invoice. Justice is done!
    Think lll get a proper job done else where for a lot less
  10. _GRP_
    _GRP_ A3 2.0TDI Sportback S-Line
    250
    Need to get my car sorted with 4 Wheel alignment after getting my coilovers fitted a few months back.
    You say your not happy with the adjustment, what are you looking for when viewing the print-out above?
    I assume they have set figures they are aiming for depending on the make/model of the vehicle?
    Can anyone explain this a bit more for me.
    George
  11. benelton
    benelton New Member
    Hopefully someone here who is knowledgable enough will see your question and give an explanation.
    My problem was that I had odd wear on my tires.very inside edge, so I asked for a 4 wheel alignment. They didn't do one at first as they said the tires were not wearing unevenly. I said your right, this is be because they are 4 brand new tires, now get it aligned you idiots.....
    then when I went to collect I was given this print out. They told me thy made adjustments but this is total BS as thy couldn't give me a before and after printout, just this one.
    The rear camber is on the limit and unbalanced. Particularly the left side. The fronts could be better also.
    Luckily their attempt to rip me off failed as I haven't actually paid. Ha
    t
  12. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Would also like to know this as I'm in the same boat after getting my coilovers fitted.
    Be good to have some figures which are considered good after alignment and what to look for.
  13. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,760
    Here's a printout from the workshop manual. You'll need the build code from the sticker in your spare wheel well, or your handbook. In my case, the S3 (highlighted in pink) has a suspension build code of UB5.
  14. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    Does anyone want to do a quick explanation to what any of these numbers actually are and what they should in fact be at lol?
    JJ.
  15. pwilliamson1991
    pwilliamson1991 Member
    77
    wtf costs me £20 for 4 wheel laser alignment at my local
  16. leeds2592
    1,399
    222
    Are you sure that's proper 4 wheel alignment with print out etc and not just bog standard tracking? If so, that's ridiculously cheap!
  17. nluk100
    nluk100 Well-Known Member
    1,035
    192
    I assume that's to check it and not for any work carried out?
  18. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    OMG £165 must of seen u coming.
    I pay £20 at a local as well on a new computer system same print out as what u got.
    just read u didn't pay that's cool beans then
  19. pwilliamson1991
    77
