Staying with Standard 288mm Front Brakes. Upgrade Options?
mixmaster Nov 23, 2011
  1. mixmaster
    mixmaster Member
    86
    I'm running 15" wheels in the winter so have to stay with the standard 288mm front discs (2.5tdi Quattro)
    They seem pretty lifeless...
    What are my options to optimise the standard front (and rear) brakes. Can they be good?
  2. aragorn
    18,438
    845
    Its all down to pad choice.
    However they're never going to be great, your car weighs 1.6 Tonnes and has the same brakes that are fitted to a 1.2 Ton FWD A4 1.8T.
    The problem is that pads which operate well at the high temps your inevitably going to generate trying to stop a heavy car, are typically a bit wooden when cold.
    I have some generic standard pads in my 1.8TQ, on the stock 288 disks, and i find that they bite well around town and even at 50-60mph they still have a sharp positive feel, but stand on them at 80mph on the motorway and they "go off" pretty quickly and you can feel fade beginning to build even before one "stop". Certainly not confidence inspiring.
    I'd suggest trying some Mintex 1144's or DS2500's as they're "fast road" pads, you may find they will be a bit wooden from stone cold though.
    I plan to change to 320mm S4 spec disks at some point. My winters are on 17" alloys as a result.
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I scared the absolute cr@p out of myself trying to stop from 70 [cough] on a slip road with a load of stuff in the boot
    brakes just disappeared about 100yds before I wanted to stop!
    pads, lines and fluid.
    ditch your fluid as a matter of course. if it is old it is probably full of water (its hydrophyllic and soaks the stuff up, which them boils when hot causing steam as a gas to form and make the brakes even crapper!)
  4. TeKnodriver
    TeKnodriver Biodiesel Purrrr
    166
    Been thinking of similar question as my discs seem to be on the way out...
    is it best to stick to genuine discs or
    would discs from ECP be any good? [Pagid / Eicher]
  5. Broken Byzan
    13,237
    465
    For the most part, disks are disks.
    I've run generic motorfactors disks for years without any problems.
  6. tangerinedream
    tangerinedream Member
    249
    only use pagid mate i work there and dont recomend eicher, pagid are damn good thou :)
