Starting to hate my car and running out of ideas
Grale1 May 24, 2013
  1. Grale1
    Grale1 Active Member
    795
    44
    As some of you may know I have issues with a left hand pull, I'm at a lose to get to the bottom, I've had hunter alignment done, replace both ball joints, both track rod ends, both inner tie rods, and got fully poly bushed wishbones and changed to coilovers.
    I'm running out of idea as what it could be, I thought maybe rack but it doesn't leak. Took it to a garage today and spent a couple of hours looking over the underneath, subframe doesn't look bent. Checked everything over, paid for another alignment as I put the poly'd wish bones on so they adjusted the toe as they say you can't adjust the castor or camber, to top it off there printer was running low on ink so I didn't get the "after" print out, I was standing next to them so I know they weren't telling a fib.
    Starting to wonder if the car is bent.
    All tyres are same pressure tread depth the same, wheels balanced correctly matching tread patterns.
    At a lose to what it could be.
    simon
  2. basil brush
    basil brush Active Member
    478
    145
    43
    binding brake ?
    first thing that popped into my head !
    voorhees likes this.
  3. superkarl
    superkarl MAN OF STEEL
    9,371
    2,369
    Bent subframe
  4. Gops
    3,194
    663
    Could be your rims?
  5. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,126
    1,968
    Could it be road camber giving the impression of steering problems ?
  6. Grale1
    795
    44
    Def not road camber, I was going to ask a friend if I could try there standard wheels on mine. Not sure how to tell if a calliper is binding ( sounds stupid I know ). I was thinking front subframe as it drifts left when you coast also, you can feel the wheels twitching every now and then through the steering wheel, like wondering on the camber.
  7. Jay 01 s3
    Jay 01 s3 Member
    124
    9
    My car is the same, all bushings are ok , car is lowered and has slight pull to the left only thing is I don't have the rear adjustable arms so its pulling , otherwise it handles like a dream :icon_thumright:
  8. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    If it pulls to the left it doesn't handle like a dream.
    A3's as stock cars were designed to lightly pull incase the driver fell asleep, they were designed to eventually take you off the carriage way. Shouldn't be noticible though.
    If it has had a four wheel alignment and was all ok it shouldn't pull, at all. So you have an issue somewhere. Are both front tires the same size? Are the track rods fitted on the right side? Have you replaced the subframe bushes?
  9. Jay 01 s3
    Jay 01 s3 Member
    124
    9
    It has a slight pull ,not as severe as grale's car but I'm impressed with its handling ; )
  10. basil brush
    478
    145
    43
    If its had four wheel alignment and still pulls it isn't suspension related surely ?
    Still putting my money on sticking caliper on the left ;)
  11. bradh
    bradh Active Member VCDS Map User
    551
    58
    i know this might sounds daft but have u got a pair of wheels u could try on the front just a couple of spares or something like that
    also are your tires directional if fitted on the wrong way they can cause similar issues
  12. Grale1
    795
    44
    Klappe, the front tyres are the same, ( AVONS ) and yes I replaced everything on both sides at the same time, and no I haven't changed the bushes in the front subframe or the rear axle, but I have noticed that the inside edge is wearing on the drivers side rear wheel
  13. 16Klappe
    5,795
    1,183
    Sounds fuuuucked :(
    Are the sills straight? When did the problem start? Bent rear beam/worn axle bushes is a possibility
  14. Grale1
    795
    44
    I had the rear beam changed its been like it since I got it but seems to be worse now, one side of the rear beam looks like it sticks out more than the other ( drivers side ). Sills look ok, it's annoying as it seems to be quite common on golfs.
    I find it hard to let the car go, I like the shape of the 8l so may have to look round for another if I can't solve this puzzle lol
  15. 16Klappe
    5,795
    1,183
    Sell it, buy a DC2.
    s33nyboy12 likes this.
  16. Grale1
    795
    44
    I couldn't afford to get rid at the moment lol, when I say it's bled me dry it really has bled me dry, I read somewhere about someone put the alignment gear from the front put on the back and back on the front and adjusted it to the rear axle and it worked??? Have my doubts about that
  17. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    You need a proper 4wa **** hunter ...everybody jumps on that band wagon..did you know you they have to know how to use it!!! you need to know the thrust angle and go from there ...if there printer is fooked tell them your money has vanished and do one.....:beerchug:
  18. 16Klappe
    5,795
    1,183
    Haha, thrust angle...
  19. Snash7
    Snash7 Member
    84
    Man its such a shame you havent sorted it pal. Saw you the other daynand the car is looking the nuts.
    I would help out but ive broken my wrist so cant drive apparently
  20. robloake
    robloake Member
    62
    Ive had a few tuned cars that all seem to do this, would it pull to the right if we lived abroad?? I think we get obsessed mate with every thing having to be on track especially when we've spent a few quid, are u happy with the motor in general?? every day I think is this right is that right but I still smile when I feel the torque, just go with it or sell it, what can you do???
  21. Grale1
    795
    44
    Thrust angel is almost dead on, it was in green at 0.02, maybe it is torque if I had the money I'd fit an LSD. Yes I do like the car I like the colour.
  22. voorhees
    16,126
    1,968
    Check your brake pads for uneven wear.
  23. Grale1
    795
    44
    I've checked the discs and pads, left rear seems to have a lip on the disc and the right side doesn't, I did look through paper work and the drivers side rear calliper was replace shortly before I bought the car, so could be a sticky/ knackered calliper as it pulls left also when braking, I think this is where I may look into more as I remembered the other week I had the car on stands on the back and the left rear doesn't spin as freely as the rear right,
  24. basil brush
    478
    145
    43
    Hooray after 22 posts since I suggested it you think it may be brake related !
    Sticky piston or slider pins , bet you ;)
  25. Grale1
    795
    44
    How would you go about unsticking the piston? I would of used cooper grease on the sliding pins on the carriers, the rear calliper piston if I remember rightly do you twist and push it to get it to go back in as if putting new pads in?
  26. basil brush
    478
    145
    43
    Silicone grease on the slider pins , yes the rear pistons wind back in and pop the front pistons out and clean them up if they are mankee
    baz ;)
  27. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    they are a bit of a sod to wind in, i done one recently... i levered with a wheel brace while the missus (need two people without the right tool) attempted to use!-) some parrot pliers to turn it clockwise, went in after 10 minutes of moaning at each other and her saying she cant lol.... bless her.
  28. basil brush
    478
    145
    43
    The full left and right handed kit is £14 on eBay , just used mine for the first time to change my rear discs and pads and is a pukka bit if kit :)
  29. basil brush
    478
    145
    43
    And for those allergic to searches the item number is
    181138724429 ;)
  30. Grale1
    795
    44
    Well passenger rear wheel spins round nicely, drivers rear doesn't spin freely and the tyre is mis shaped also, but I'm not sure if that could be the problem
  31. 16Klappe
    5,795
    1,183
    Yup, quite easily.
  32. superkarl
    9,371
    2,369
    Lets all sell our cars and get on with our ****ing lives eh.
    andy1571 and 16Klappe like this.
  33. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    195
    The old saying " if its got tits or tyres its gunna cost ya" ;-)
    superkarl likes this.
