Starting problems
ASHBEE Dec 20, 2009
  1. ASHBEE
    ASHBEE New Member
    hi all could really do with some help. i recently couldnt start my a3 was told it was the starter .... had it changed still couldnt start .......... so i put a connection from starter just a wire and i touch the battery with other end of wire then it starts no problem >>> i changed the plug to the starter still no joy..... ive checked all connections and cleaned them up my barrel in ignition is good as it turns and pops back correctly anyones advice would be welcome . as to start it is a hole process i could do with out ????????????????????????????????????????????
  2. ASHBEE
    ASHBEE New Member
    really could do with some advice boys ????
  3. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,132
    1,971
    I think you should try using some patience
  4. cabriolet
    cabriolet Member
    58
    take it u mean the little lucar in the tunnel fella if its the same as golfs the wire dies and u need to put a new feed from the ignition to the starter
