Starting problems with a3 1.8
Fatalignition Dec 18, 2010
  1. Fatalignition
    Fatalignition New Member
    Hi,
    I'm pretty new to the world of Audi ownership as I recently bought a w reg 2000 A3 1.8.
    It's been fine until today when it's not been starting, it seems to start fine in the morning and after work (when it's been sat for a while. I drove the car for about 20 minutes to the shops but then it wouldn't start after about 30 minutes of it being switched off. I eventually got it started after having to rev while turning the ignition. I then got home, turned off the ignition and tried starting it up again and it failed. But after leaving it about an hour it started fine? I'm not mechanically attuned what so ever.
    I just wondered if anyone could give me a but of advice? I did google it and it said to put it on vagcom? I've no real idea what that is.
    Any help would be greatly appreciated!:yes:
    Cheers.
  2. stu_b
    stu_b Member
    59
    I had the same trouble with mine does it sometimes squeal after start up?
    If so it could be the bearings in the starter are goosed.
    It could as be worth giving it a service if its a new car to you new plugs etc all might help
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would give it a full service and see how you go,, if still a problem you need to get it on the vcds or you maybe chasing rainbows,.....
  4. DenCar
    DenCar Member
    404
    Find someone with a Vag-Com (VCDS) to read any error codes, the codes, if any, may point you in the right direction. to your starting problem.
    Good Luck
    DC
  5. jay1601
    jay1601 Well-Known Member
    1,347
    73
    mine does this sometimes aswell, i know mine is the starter motor is on the way out
