Starting problem
ASHBEE
hi all could really do with some help. i recently couldnt start my a3 was told it was the starter .... had it changed still couldnt start .......... so i put a connection from starter just a wire and i touch the battery with other end of wire then it starts no problem >>> i changed the plug to the starter still no joy..... ive checked all connections and cleaned them up my barrel in ignition is good as it turns and pops back correctly anyones advice would be welcome . as to start it is a hole process i could do with out ????????????????????????????????????????????
Have you checked fuse F15 under the bonnet in the fuse box
Did you resolve your issues Ashbee?
