starting issue when hot
4rings Oct 14, 2011
  1. 4rings
    4rings Member
    94
    hi been having a few problems. when the car is cold e.t.c the car turns over and starts fine. when the engine is hot however sometimes you turn the key and its really slow and turning over then all of a sudden it will turn over fine and fire into life. the battery si fine all been tested. im guessing its the starter motor on the way out??
  2. a3tdi2001
    a3tdi2001 Member
    437
    Apparently the starter motor suffers from heat soak from the engine/gearbox as written by another member on this site. This could well be causing the problem. May last a while before it gets any worse.
  3. jay1601
    jay1601 Well-Known Member
    1,310
    57
    any fault codes
    temp sensor caused this problem on my car.£5 fix :)
