Starter motor and or battery issue?
Iceash Jan 21, 2014
  1. Iceash
    Iceash Member
    391
    10
    Hi all,
    noticed in the mornings before I turn over the engine the volt meter is sitting just under 12v that's not normal is it? Also recently noticed once engine fires I briefly get a sqark noise I can only imagine that's the starter motor! Could the lower voltage cause that? Doesn't do it all the time though.
    thanks,
    Ash
  2. aragorn
    18,442
    846
    I think mine sits in a similar position.
  3. Iceash
    Iceash Member
    391
    10
    Sounds like I'll just need a new starter then.
  4. Iceash
    Iceash Member
    391
    10
    Could it be a sticky relay?
  5. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,676
    2,572
    The starter motor wouldn't cause the battery voltage to sit under 12v that sounds like a battery issue.
    If it's over 5 years old then it's past it's best.
    You need to check the alternator is charging correctly and if so I would invest in a new battery and go from there.
    Car parts for less are about as cheap as you get for good quality batteries.
    Car Parts Online, Spare Parts, Motor Spares from CarParts4Less.co.uk
    Karl
    Iceash likes this.
