Started the 2.1 today but....
Andrew@A.L.D Apr 17, 2010
  1. Andrew@A.L.D
    3,877
    617
    It engine sounds sweet but its the cooling thats the problem
    I think there is still a bit of air lock, the fans don't want to kick in and the temp just goes up
    Just want to cover all problems that may happen?
    Will i have put the thermostat in the wrong way and not known i have done so?
    Will i need a new fan switch?
    anything will help
  2. Imteyaz
    Imteyaz 6th Gear
    535
    Have you tried running the car with the expansion cap off to help any airlock to escape? (obvious one I know, it's easier to start with the easiest fixes then move on to the more awkward ones).
    I didn't think that the thermostat would fit the wrong way round but open to other peoples better qualified opinions on that one.
    What do the hoses feel like? are they all getting hot or are some still cool? Do the pipes feel hard (pressure build up?).
  3. Andrew@A.L.D
    3,877
    617
    I have run it with the cap off and it just bubbles away, just gets hotter and hotter, all pipes seam hot
  4. Imteyaz
    Imteyaz 6th Gear
    535
    I take it you tried squeezing the pipes too whilst running the engine? I suppose you could always check the stat to see if that is the problem but bubbling is normally associated with broken waterpump impellers causing lack of / limited circulation. Has the waterpump been replaced?
  5. Imteyaz
    Imteyaz 6th Gear
    535
    Just found this response from Vortex in response to a guy who has similar probs:
    "when the car is at operating temperature, is there a difference in the temperatures of the upper and lower radiator hoses? Did the car start overheating before you replaced the coolant flange. I would start by checking the upper and lower radiator hoses, if the upper is HOT and the lower is cold, i would suspect the waterpump or thermostat. remove the thermostat and inspect the waterpump with a small mirror. Replace the thermostat and re-check the cooling system.
    If both of the hoses are hot, and the fans are not operating when up to temp, i would start by checking the green fuses, in the fuse box on top of the battery. the battery boxes start to melt, and make poor contact. remove the 3 green fuses and check the inner terminals for corrosion and burn spots. Don't rule out the possibility of an air pocket in the system not turning on the fan switch or a bad fan control module."
    HTH mate,
  6. badger5
    9,471
    1,988
    heater in car on full also?
  7. Andrew@A.L.D
    3,877
    617
    Put the heaters on full inside as hot as i could and there blowing hot
    Run it with the cap off and just gets hotter and bubbles over when fans are meant to kick in also i'm coming up with a fault code of 17748 camshaft/crankshaft position sensors (B2) out of sequence
    Checked the new thermostat and thats the right way round and i also fitted a new water pump when engine was build
  8. Andrew@A.L.D
    3,877
    617
    Could it be the fan switch? but as i said before that fans don't kick in?
  9. badger5
    9,471
    1,988
    cam position sensor is a pain.. out of synch either on cam to cam and/or cam to crank..
    arse of a job to redo and check
    hatefull..
  10. badger5
    9,471
    1,988
    if a/c is turned on fans should start on low speed.. which checks fan function
    what water temp does engine think its got on vagcom, vs instruments.?
  11. Andrew@A.L.D
    3,877
    617
    Cam to cam was spot on i think its cam to crank thats out
    Don't have vagcom, the instrument keeps going up and doesn't stop
  12. Andrew@A.L.D
    3,877
    617
    Water pipes are soft but hot and same with the lower hoses but when i checked the thermostat hardly any water came out?
  13. Andrew@A.L.D
    3,877
    617
  14. S3KO4
    S3KO4 Member
    850
    I had green fuse blown and the temp went up with loud warning beebs, so it fan was not coming on at all. hope it is simple.
  15. Andrew@A.L.D
    3,877
    617
    I'm hoping its the green fuses
    Anyone know what amps they are?
  16. Andrew@A.L.D
    3,877
    617
    Ok not a happy bunny
    Fixed the fan and the ABS, it was the multi plug that plugs to the fuse box on top of the battery.
    Thats the good bit the bad bit is the engine is smoking now so i thought i drain some oil off as there was a bit to much in and its still smoking
    It didn't smoke the first time i started it up but i came to it this morning and its started smoking?
    Its white smoke so i'll have to look into that?
  17. <tuffty/>
    21,140
    3,828
    Hummm... white smoke and over heating.... head gasket?
  18. Andrew@A.L.D
    3,877
    617
    Thats what i was thinking?
    I it is i just hope the head doesnt need a skim
    I could of also damaged the head gasket when putting the head on???
  19. <tuffty/>
    21,140
    3,828
    The are pretty tough tbh... you didn't do what Welly's mate did and put the head gasket on upside down? LOL
  20. Andrew@A.L.D
    3,877
    617
    No not at all lol
    I just done have time to do it now as i'm behind on my work and might drop it off at a garage to get it fixed as i need it asap now
  21. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    bummer hope you get it sorted..:icon_thumright:
  22. Andrew@A.L.D
    3,877
    617
    Just wiped the cylinder head off in a hour and the bores were full of antifreeze and you can see were the gasket had warped from getting to hot
    Just got to order some new parts again
  23. s3dave
    10,110
    736
    do you know how its happened? you dont want a repeat....maybe get the head skimmed?
  24. Andrew@A.L.D
    3,877
    617
    The plug that plugs into the little fuse box on top of the battery wasn't connected properly, that plug controls the fans and ABS, The car then overheated on the spot i didn't notice it over heating until it started to beep and steam a little, i stopped the car and put it away so when i came to it the next morning a lot of water had been dumped into the bores.
    The head has been skimmed prior to the build and have just checked it now and it seams to be fine and true and as tuffty said there pretty tuff the heads
  25. badger5
    9,471
    1,988
    for just idling thats a surprising fail for temps on idle..
    i always watch guage and startup with vagcom connected to keep an eye on things, whilst also going all round it with torch looking for smoke, drips etc etc
    done it many times, and i always get nervous starting a fresh build/install....
    sorry you have hit a problem so soon.
    bill
  26. Andrew@A.L.D
    3,877
    617
    Its didn't help with the fans not working at the time
    To be honest Bill i think i may of damaged the head gasket when i was putting the head on
  27. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Im having a similar problem. Just put my head back on and the engine seems to be smoking quite a bit at the back but I think that is because I put a new exhaust mani gasket and mani to turbo gasket on so think that maybe the cause for the smoking at the rear of the engine.
    The car also comes up with a 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation P1340 - 35-00 fault. The are a number of reasons for this fault but unsure which to try first.
    The first time I started the car it started fine and idled fine but smoked at the rear and sounded very tappy (read this maybe because the exhuast mani wasnt torqued up enough - 25nm) and then when the car got up to temperature it just cut out and wouldnt start back up till the engine was cold but then cut out again after a few minutes.
    Could I have damaged the head gasket when I put it back on and how would I know the gasket was put on the right way up. Any help would be great Nathan
  28. Andrew@A.L.D
    3,877
    617
    Why was the head gasket changed?
    The 2.1 of mine is been rebuilt due to oil starvation to rod 4, oil has been going to it but not much
    The crank will have the works done to it and it will be fitted with Total seal piston rings
  29. S3 Nattie
    1,599
    The head got taken off so replaced the gasket at the same time. It only seems to be smoking at the rear of the engine bay where the new gaskets were put in and smoked till the engine cut out which I believe maybe due to the crankshaft sensor.
    Would you happen to know why the engine was so tappy and does the crankshaft sensor relate to the engine cutting out and stuggling to start back up again and the 17748 fault code. Is there a way to check the head gasket is on the right way up.
  30. Andrew@A.L.D
    3,877
    617
    The smoke will be from the new gaskets and will go away in time
    The engine shouldn't cut out, if the timing is out it will run like a pig. Have you got the timing right between the two camshafts and the camshafts to the crank?
    Tapping could be due to the timing been out the wrong oil?
    if the head gasket was wrong then you would get oil/water mix in the header tank or blue/white smoke out the exhaust
  31. S3 Nattie
    1,599
    I do believe the smoke is from the new exhaust mani and turbo gasket but it taking ages to go away.
    The timing is fine I believe. The crank, cam gear and the 16 roller distance between the two end bearing caps are all lined up and the make on the flywheel was also used and they were all lined up and the car idles perfectly fine so assume the timings fine.
    There was a little bit of white smoke from the exhaust but nothing to worry about, mainly from it being stood for such a long time (3 weeks). Could a leaking exhaust mani cause the ticking. I tightened the mani up to 25nm and the mani to turbo 40nm. Also could the crank speed sensor be the cause for my engine randomly cutting out and not starting again or a while, 17748 I got does suggest it.
    Nathan
  32. Andrew@A.L.D
    3,877
    617
    I still think its timing, a sensor wouldn't breaks down if stud for 3 weeks
  33. Andrew@A.L.D
    3,877
    617
  34. Lee172
    Lee172 GT3071
    430
    I am having troubles with the same fault codes at the moment, i just had the cambelt done so im putting it down to the timing being out... my car seems to idle and run fine. some one said on another thread that the ecu will adapt so it will run ok, Its going back to the garage on monday so i will let you know the outcome.
  35. S3 Nattie
    1,599
    the car idles perfectly fine and starts fine but stalls on its own randomly after a while. Surely if the timing was out the car wouldnt start vry well and idle roughly.
    The cambelt snapped and it did make a pop sounds as thought something just blown so i been thninking a sensor went when the cambelt broke ( on my drive idling the belt snapped ) and thats why i asked about the crank sensor as thats also a solution from vag com.
    I will check the timing again then first before i buy a sensor
  36. S3 Nattie
    1,599
    That would be great if you could get back with your outcome. Does your car cut out randomly at any time as thats the main problem with mine, it starts and idles perfectly fine but cuts out when it wants which leads me to believe the crank sensor maybe at fault.
    Nathan
  37. badger5
    9,471
    1,988
    if you have correlation error, your cam belt is off a tooth or so
  38. badger5
    9,471
    1,988
    your cambelt snapped when the car was idling on your drive - really?!?!
    valves checked?
  39. Lee172
    Lee172 GT3071
    430
    Well i have the same codes as you but the symptoms are slightly different.. mine runs fine and idles well most of the time, which is what is confusing me, i thought if the timing was out it would run roughly??
    If you read the thread 'what have they done??' thats about what is happening with my car. When i go back i will deffo let you know .
  40. S3 Nattie
    1,599
    Ye, im a bit confused to as my car starts and idles fine. I thought it the timing was off the car would start and idle roughly which mine doesnt.
    Would anyone be able to tell me if the engine would cut itself off if the above code appeared because thats what my car is doing.
