Start Stop Question
MattyW19 Mar 15, 2011
  1. MattyW19
    MattyW19 Member
    401
    Hi,
    Just an interested in asking about the start stop on my car. I have a 1.4 TFSI which on the order form said had start stop.
    I have put it into neutral, and applied the hand brake and lifted off the clutch, yet the car stays at tick over revs?
    Is there something I'm doing wrong?
  2. slade777
    slade777 Member
    763
    Is the car up to temperature???
  3. MattyW19
    MattyW19 Member
    401
    Yes, I didn't think of that, but it was at 90!? I was trying it after a 10 minutes journey
  4. BlueSpark
    BlueSpark 6th Gear
    386
    the courtesy car i got when i had mine serviced had start stop. On that when i stopped at traffic lights, foot on brake, nuetral and lift clutch up, the engine stopped. As soon as i pressed clutch down, selected 1st gear and as bringing clutch up it would start and go. it was a a4 avant 2010 2.0tdi by the way.
  5. slade777
    slade777 Member
    763
    Maybe the heater inside hasn't reached correct temp yet? Mine didn't cut out in the cold because had the heater on full and it was trying to keep the temp.
    Also mine sometimes doesn't switch off it I stop and apply the handbrake to quick.
  6. sub39h
    sub39h Active Member
    2,502
    there are loads of things that determine whether the car will cut out or not - operating temperature, what electronic gadgets you're using etc. i recall on a review of the 1.4 start/stop that it wasn't great and didn't work a lot of the time. it may well be because it's still too cold outside or something.
    keep having a play, and if all else fails i'm sure the owner's manual will give you a clue as to what's going on.
  7. MattyW19
    MattyW19 Member
    401
    Thanks for all your replies. Yeh, I'm using the radio and have the heaters on - which may be the answer? I'm having a trip out tomorrow, so I will try and have a play! As sub39h suggested, I'll be checking my owner manual if I can't figure it out!
    I'll let you know how I get on, I was just interested really, because I thought it would be instant cut off, but seems abit more complicated than I had in mind really.
  8. mike foster
    3,967
    I'm probably wrong but I thought I read somewhere that you can actually switch off the stop/start system !!!
    Why they would do that though is a mystery !!
  9. Harrelson
    Harrelson Member
    173
    mine is almost always switched off.
    the air-con in my a3 is absolutely terrible and when start stop kicks in the vaguely cool breeze from the air-con turns into **** warm air directed at your face.
  10. MattyW19
    MattyW19 Member
    401
    Yeh, I have heard about that? I was searching through and I couldn't find anything to do with it.. I probably wont use it, but I just wanted to see what it's like!
  11. MattyW19
    MattyW19 Member
    401
    Got it working now! I just randomly tried it after a motorway journey and it started to work!
  12. mike foster
    3,967
    So, is it any good, or not ?
  13. MattyW19
    MattyW19 Member
    401
    Hmm, it's ok but I wouldn't use it all the time, for example if I was in traffic and it wasn't moving then yes I would use it, or if I was waiting for someone It's much easier than messing about turning the engine off and on. But I think it's abit of a pain when at traffic lights tbh!
  14. mike foster
    3,967
    So basically, 'no', is the answer !
  15. MattyW19
    MattyW19 Member
    401
    In around about way yes, I like the choice of having it, but I can see why it can be turned off.
  16. s66614a
    s66614a New Member
    9
    I find it quite good but its on a S tronic so goes off when you put your foot on the brake pedal and stop moving.
    If you brake gently to a stop and only put light pressure it stays on, can cause an issue if trying to pull out in traffic and its stopped though.
