Start Stop Function
Superman23 Nov 28, 2012
  1. Superman23
    Superman23 New Member
    25
    Can someone please tell me if it is possible to switch off the start stop permanently or if it is on again every time the car is started?
  2. h5djr
    9,414
    1,740
    As far as I'm aware there is currently no way of switching it off permanently. I have the same system on my A3(8P) and I have spoken to an Audi Master Technician and the dealers have been told not to do it as it would affect the cars C02 rating and thus it's tax requirements.
    But if anyone does find out how to do it, I would also be interested!
  3. Superman23
    25
    I take it that it can be switched off on a specific journey if you don't want it to work?
  4. dieseldoug
    dieseldoug Member
    240
    53
    It might be worth wile looking in to the logic, currently only works when the car has been above xx MPH, engine running, in neutral and brake applied.
    There may be a switch on the gearbox that detects neutral and clutch pedal not pressed which will stop the engine, it automatically starts when the clutch is pressed again, maybe a switch at the clutch pedal, may requires jumping out....
  5. peterw47
    peterw47 Member
    85
    12
    I like the auto start stop in principle, such as sitting at lights for a minute, but in crawling traffic it's a pain! Of course you can get both situations on the same drive so rather than turning it off altogether, I just rest the gear stick on 1st so the car doesn't realise it's actually in neutral (so doesn't cut engine). Perfect for crawling in traffic.
  6. Audion
    Audion New Member
    You're going to destroy the clutch plate that way :sadlike:
  7. Vertigo1
    Vertigo1 Well-Known Member
    3,392
    550
    If you don't want it to cut in then just don't put it in manual or even do so but don't lift the clutch. Alternately just hit the switch to turn it off, although this does only work until the next time the ignition is turned off.
  8. ChrisJL
    ChrisJL Member
    44
    Whether its the same for the A3 or not. But In my A1. I have the fan on the wind screen (but I manually toggle the AC off) and it would seem that when the Button is pressed to put the fans onto the windscreen the car never auto stop / starts. Only when I knock the fans off completely and then stop at a junction does it then do the stop start. But as soon as I put the fan back on, the engine starts again without touching the clutch.
  9. cotball
    cotball Member
    35
    Just get into the habit of switching it off every time you get in the car.
