Stange Starting problem ?
S3mad Oct 14, 2008
  1. S3mad
    S3mad Dark Knight
    947
    Hi all ,
    started the car today and took a a few more turns than normal then started from cold . Then started at work after work and did the same why would it be doing this ?
  2. jamieface
    jamieface the only S3 in the villiage
    196
    hey there i had the same problem with mine and it turned out to be the cam sensor/crank sensor, it can also be the temp sender unit too, your best bet is to see if anyone on here can doa scan with vagcom for you to try and narrowit down a little
  3. S3mad
    S3mad Dark Knight
    947
    Whats the best way to test i tryed my code reader and no codes where found ?
  4. S3mad
    S3mad Dark Knight
    947
    anyone have what to check 1st ?
  5. Bellic
    Bellic Member
    265
    i would try temp sensor first
  6. S3mad
    S3mad Dark Knight
    947
    Funny thing i had my cam gasket changed and only happened since then . I took the temp sensor of and cleaned and then started again in morning and was fine ??
