Standard to aftermarket
Innocence80 Jul 30, 2013
  1. Innocence80
    Innocence80 Member
    232
    32
    I am looking to swap out my standard stereo (because it's ****!) and replace it with a sony unit, what sort of connecting harness will I need for the wiring. Hoping there is a plug and play solution.
  2. palfy86
    palfy86 Active Member Audi A4
    362
    75
    What stereo do you have in currently?
  3. Innocence80
    Innocence80 Member
    232
    32
  4. Innocence80
    Innocence80 Member
    232
    32
    Anyone? :(
  5. palfy86
    362
    75
    Ive got the same stereo and to be honest ive never had it out (pardon the expression) but given the resources i have access to at work it looks as though its on standard ISO leads two oblong blocks. Might depend if you have bose system as well.
  6. Innocence80
    Innocence80 Member
    232
    32
    So will an Audi to Sony ISO do the trick?
  7. palfy86
    362
    75
    Have a search through the "in car entertainment" threads innocence80 sure it'll be mentioned in there. :thumbsup:
  8. palfy86
    362
    75
    Probably best thing you can do is whip it out and take a peek before you get buying any leads and possibly things you dont need.
  9. Innocence80
    Innocence80 Member
    232
    32
    How do I know if I have the full Bose system? I have the Bose speakers but haven't noticed any amps or anything but I haven't exaclty looked either!
  10. palfy86
    362
    75
    Im not 100% on this and im sure folks will jump in and correct me but id imagine if you've got the bose speakers you'll have the full system, amps etc are usually tucked away out of sight ( in the boot walls etc)
  11. crazy88
    crazy88 Loving the anonymity
    4,938
    437
    Does the headunit say bose when you turn it on? As far as I know the bose units do. As for the full system, i'd say it's very likely if you've got bose speakers, unless someone has just upgraded them, or stuck new grills on?!
    Amps are in the boot as above. The drivers side boot compartment is where my amp is housed. It should say bose on there i'd imagine.
  12. Innocence80
    Innocence80 Member
    232
    32
    I will have a look tonight and let you know!
  13. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    if you dont mind me asking why sony ?
    the best thing you can do is go to a local independant store and have a listen to a few units from differant manufacturers
    they will also be able to advise you which lead will fit whatever unit you prefer
    sony have not made great head units for quite some time , pioneer and alpine are still making fantastic units
    if you want something that looks like its a standard factory fit look for a make called "becker" or rarer still "nakamichi"
    they are both very standard looking but match the insides of an audi quite nicely
  14. Innocence80
    Innocence80 Member
    232
    32
    Sony because I have the headunit sat at home, had it a couple of years now and I like it, means I can plug my ipod into it etc. Don't want to buy another headunit if I don't have to.
  15. dualmono21
    1,132
    no problem
    if its something you allready have
    drop into an independant car audio store and ask them if they have a lead which is suitable for sony
  16. Innocence80
    Innocence80 Member
    232
    32
    Had a quick glance in the boot this morning, couldn't see anything and don't want to start pulling the car to bits, there is a cover which says 12v on it, looks like its for a fag lighter type connection though.
  17. Mollygoogle
    Mollygoogle Member
    227
    You have to take the side panel out of the boot to see the amp, takes seconds and goes back in to place easily.
    You will need the adaptor that converts the outputs of the Sony to match the inputs of the Audi/Bose amp, adaptor for the aerial, a 12v switched live from the fusebox or similar.
    Does your Sony unit have RCA outputs?
  18. Innocence80
    Innocence80 Member
    232
    32
    Erm....I think so! :uhm:
  19. Mollygoogle
    Mollygoogle Member
    227
    you need to check as the aftermarket adaptors use the RCA output to feed the factory fitted amp
  20. Innocence80
    Innocence80 Member
    232
    32
    Will have a look tonight if i get time.
  21. Innocence80
    Innocence80 Member
    232
    32
    Well I don't have an amp so managed to get an ISO but the aerial is knackered so need a new connector for that.
  22. Mollygoogle
    Mollygoogle Member
    227
    You don't have an amp already in the car?
  23. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    ALL Audi OE head units use an external amp:
    - if you have Bose then it's a 4 channel amp
    - if you don't have Bose then it's a 2 channel amp for the rear speakers with the front speakers connected directly to the head unit.
  24. Mollygoogle
    Mollygoogle Member
    227
    this ^^
  25. Innocence80
    Innocence80 Member
    232
    32
    Right, my head unit is finally in after 3 different tries with ISO cables and a bit of playing around to get the amp to fire up! I have the Bose system. Some idiot though has cut the end of the FM aerial, so need to get this fixed as only able to get heart fm at the mo!
