Standard S3 turbo/exhaust system. Common blow points?
Schlaag Jun 18, 2012
  1. Schlaag
    Schlaag Bwah
    486
    32
    Hey oop all
    I get a fairly loud grumble/rumble when putting the car under load at low revs (before turbo starts to spool)
    First instinct is that the exhaust is blowing somewhere
    Has anyone had this 'orrid rumble/grumble from their car?
    I may be hearing things but it sounds like its coming from under the bonnet... so obviously i'm thinking downpipe/turbo exh housing flange or manifold.
    Are there common weakpoints on these areas at all?
    Car hasnt been dicked about with massively. Its std bar a B5 TIP/JR cone in std airbox and an 008. I would like to get it a stg 1 revo or r-tech map but want it tip top before I start turning up the heat so to speak.
    muchos gracias
    Dave
  2. <tuffty/>
    21,965
    4,239
    Most go at the turbo/mani gasket... the turbo/mani bolts back off over time due to heat cycling and the looseness then promotes blow by the gasket... common as hell
    Only other place they tend to go is the flexi on the DP... if its gone there then just fit a 3" and be done...
  3. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Dont know if its the same noise or not but since fitting my Jetex induction kit i get a bit of a throaty rumble from under the bonnet when i start to rev the car nothing its sounds quite mean lol.
  4. Maz
    Maz Moon is made of green cheese
    1,004
    14
    I think it's a side effect of having the B5 TIP and open cone fitted but in a good way, I actually like it!
  5. vrbob
    2,375
    171
    i dont have a B5 Tip just a silicone one but it defo gives it more of a growl at low revs with the cone filter :)
    i did have a quick look at hiding it inside the OEM airbox whilst in was doing the N249 delete over the weekend but decided i would keep the kit as is and that way i can put it back to standard in necessary. Just gotta make some sort of heat shield like i have seen on others.
  6. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Is the sound a bit like a deep gargle (oo errr)? If so mine does this. I've got a 3" d/p to go on soon so I hope that cures it. How hard is it to change the turbo/manifold gasket..?
  7. Schlaag
    Schlaag Bwah
    486
    32
    Aaah didnt suspect the JR and TIP.
    Here is a scenario... imagine you are pootling along in 3rd gear, low revs. Then put foot to floor. Obviously there is no power band so the engine labours till revs / boost picks up.... Its this point I get this grumble / rumble noise
    It's now making me paranoid and now I'm thinking im losing power as a result.
  8. <tuffty/>
    21,965
    4,239
    That sounds like induction noise to me... its the same sorta noise they make on the dyno as Bill loads the car up for a run...
  9. vrbob
    2,375
    171
    i notice it most in first gear if i have the window down and i start to pull away it makes the grumble tioll the revs pick up and then it makes the wooshing air moving noise.
    Not noticed it in higher gears but guess thats cos wind noise is higher etc will see if it does on my way home tonight as am still seeing if the N249 delete i did has made any difference.
  10. vrbob
    2,375
    171
    Just to add to this i listened on my journey home after work and the growl i get is if i am below 2k in any gear and holding a constant speed and then accelerate i get this noise until the revs go past 2k.
    mine is defo related to the induction kit, so Schlaag perhaps to confirm this you could de-stealth your airbox setup and see if the growl gets louder as this should confirm the jetex B5 combo as the source.
  11. JakeOwen
    JakeOwen New Member
    9
    Sorry to bring up an old thread.... did anyone find a cure for the grumble / rumble at low revs whilst pulling away ?
    Many thanks, Jake
