Standard or not 1.8 t
20va4 Jul 31, 2011
  1. 20va4
    20va4 Member
    Hi peeps ive got a 96 1.8 t AEB not sure if it is standard cuz it goes really well if u no wot i mean the boosting side of things is 1000 rpm to 3000 it spikes at 9/10 psi and 4000 rpm to 6500 it boost 6/7 but I will do well over 140 mph is this right 4 standard how will I now if It's been chipped or remaped don't now if any can understand wot I mean lol
  2. Oranoco
    Oranoco Well-Known Member
    3,868
    381
    iirc standard boost is 7psi. Mine is chipped and peaks and holds 10-12psi for 181bhp and a top speed of *70mph* on the speedo then it seems to hit a wall.
  3. aragorn
    18,150
    766
    The book indicates a top speed of 135mph for a stock 1.8T FWD.
    The speedo does overread though, so an indicated 140-145 seems about right.
    I'd say your boost figures sound standard.
  4. mike-a
    mike-a Member
    103
    If it's a 96 AEB and it has been remapped then it'll have had a physical chip change as you can't remap them through the obd port.
  5. 20va4
    20va4 Member
    Wicked cheers can I open the ECU and have a look if there's a different chip
  6. NineNails
    NineNails Proud sponsor of the snack food industry
    591
    Yep
  7. 20va4
    20va4 Member
    would the chip have a name I.E super chips or something like that
  8. bmarshall
    bmarshall Member
    I have a 96 with a chip that boosts to 12-14psi, the chip is not labled though.
  9. 20va4
    20va4 Member
    kk cheers ill have a look c wots goin on
  10. NineNails
    591
    This is my chipped ecu. You can see the large chip rased on a 'piggy back' at the bottom of the board, On a standard ecu there is just a small chip soldered to the board itself. My ecu was like this when I bought the car and there is nothing to indicate who's chip it is. I don't know if there is a way to find out because I'd be interested too!
  11. 20va4
    20va4 Member
    can i have a look when the ecu is on the car or do i have to take i off if so will i need vag com to set it back up
  12. NineNails
    591
    No you won't need to set it back up but you will have to remove it from the car because it is inside a metal case. There's only 2 plugs connect it to the car. Just ull the tabs on the side of the plugs and they pull out. 4 Torx screws secure the board in the case but can't remember the size sorry
  13. bmarshall
    bmarshall Member
    The 96 square ecu has 5 small coloured plugs.
  14. 20va4
    20va4 Member
    kk cheers
