standard lights to l.e.d
vw754 Feb 28, 2014
  1. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    Hi, i have standard rear lights on my 58 plate b8 tdi,if i buy genuine L.e.d's what do i need to fit them as regards to wiring them up?
    will they wire up properly and not give any errors?
    What will i need to complete the job/how much?
    p.s ........i do have vcds (vag-com)
  2. andyam
    andyam Active Member
    485
    Vag. And adapter cables. From what I have read that's all that's needed. I need to get a set and install on mine too lol
  3. paul-psa
    paul-psa Member
    81
    Or buy Plug & Play L.E.D s? there is another thread on here somewhere about this same subject, many have gone the complicated way round this problem, wiring harnesses!, Vagcom programing!, new connector plugs, the list goes on!
    I just fitted plug & play LED's, do a search and they will come up! they are straight forward swop just need to keep your back plate from your original non led rear lights.
  4. vw754
    2,345
    58
    only want original led lights,non gens look s**h in my opinion.
  5. dpaz
    dpaz Active Member Team Tango
    526
    115
    43
    What do you mean by LEDs?
    You mean the Xenon + DRLs headlights?
  6. paul-psa
    paul-psa Member
    81
    Mine look identical to oem's, infact you just cant see any difference? Not cheap either! About £53 cheaper each then oem's, just saves all the messing about, these had my neighbour fooled a while back with his 12 plate, we parked side by side look identical to his.
    Just need to buy the right ones!
    Ah well ! plod on mate.
  7. vw754
    2,345
    58
    which one you got,and how much,ive just seen some right nasty looking ones thats all
  8. vw754
    2,345
    58
    as stated above in my post i have standard rear lights'
