standard cd changer died
S3_chris 11 Apr 1, 2013
  1. S3_chris 11
    S3_chris 11 Member
    188
    As above. Was working fine till I put a new cd in today, now registers as no cd. And cant eject the cassette as sounds like there is no power or the motor has packed up. Any ideas guys?
  2. S3_chris 11
    S3_chris 11 Member
    188
    Just wanted to know if anyone had any ideas before I start taking it all out. Cheers guys
  3. JRock247
    JRock247 Active Member VCDS Map User
    509
    45
    I would scan it with VCDS 1st, see if that throws up any faults. Failing that, remove the changer and check wiring between changer and head unit.
    If no sound coming from it, might have broken motor or power control circuit.
    Post back your findings.
  4. S3_chris 11
    S3_chris 11 Member
    188
    I havent got vcds unfortunately and dont know anyone with it near me. Was working fine until I put a new cd in it now wen u push eject nothing happens sounds like no power tbf but on the atandard unit it says no cd not sure how when theres 6 inside
  5. JRock247
    509
    45
    It could be a power issue or communications issue between unit and changer. Not sure if the changer has an internal fuse, maybe check that. Try removing it and reconnecting, not difficult to remove both.
  6. OllieGSR32
    OllieGSR32 Member
    41
    I had exactly the same problem. I couldnt work it out I had to force the cd cassette out to get my cds and it busted the internal clips. Didnt bother me as i was changing to an after market cd HU and stealth sub enclosure. Try pressing the eject several times see if its an intermittent fault.
  7. JRock247
    509
    45
    I read on another form, that if you remove the 'communication' fuses (x2) you can force the cd changer to reset itself. Try removing the side panel on the dash to reveal your fuses, locate communication fuses (use your manual) and remove the fuses and re-insert, see how that goes. You may want to jot down your radio code before you attempt removing it or the fuses.
