Standard Bose system
Todd1983 Jul 14, 2012
  1. Todd1983
    Todd1983 Member
    147
    Without having to remove it, does the standard Bose system head unit have the capabilties to add a sub. I was contemplating it but want to keep the interior and oem so avoid changing head unit. Or is it a possibility to upgrade to a later model?
    Thanks in advanced
  2. adamss24
    adamss24 Well-Known Member
    4,584
    407
    What do you have saloon or estate ? The estate has a active sub built in the boot side, behind the trim panel and on the saloon there's 2 free air subs on the parcel shelves...
  3. Todd1983
    Todd1983 Member
    147
    Interesting, saloon
  4. aragorn
    18,606
    871
    as above. Saloon has 6 speakers, the four door speakers are normal full range units, and the two on the parcel shelf are subwoofers. Not particularly great subwoofers mind.
    If you wanted to add your own, you could always disconnect the parcelshelf speakers, and tap into the line level signals on the appropriate wires at the bose amp for your own amplifier.
  5. Todd1983
    Todd1983 Member
    147
    That's good to know that the wiring is present, thank you
