Standard Boost for a 180 bhp AJQ engine
666markyboy Sep 15, 2008
  1. 666markyboy
    666markyboy Well-Known Member
    1,211
    49
    What should the standard boost be for a AJQ 180 bhp motor ??? i'm seeing around 0.6 BAR max but searching the forums this seems to be the same as a 150 bhp motor i thought it would have been a touch higher.... i'm sure someone must have the figs for standard engines knocking about...
  2. 666markyboy
    1,211
    49
    found this on 2 diff engines so maybe it's not far off after all
    Engine Code: AWM
    Model Years: 2001-2005
    Compression Ratio: 9.3:1
    Horsepower (SAE Net): 170 @ 5900 RPM
    Torque: 166 ft. lbs. @ 1950 RPM
    ECU: Motronic ME7.1
    DP Size: 50mm (1.97")
    Turbo: K03s
    OE Boost: .6 Bar (8.7psi)
    Engine Code: AWP
    Model Years: 2002+ (06/01 on)
    Compression Ratio: 9.5:1
    Horsepower (SAE Net): 180hp @ 5500RPM
    Torque: 174ft. lbs.@ 1950RPM
    ECU: Motronic ME7.5
    Turbo: K03s
    OE Boost: .8 Bar (11.6psi)
  3. Bellic
    Bellic Member
    265
    my ajq was showing 0.8 bar which is right for 180bhp engines
  4. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    Also AJQ engine is ko3 not ko3s,definate.Cheers Andy
  5. 666markyboy
    1,211
    49
    Yeah i'm getting around 0.8 Bar now after changing the bulb in the gauge which was catching on the mechanism inside ...... shame on the turbo though... would have been nice to have a KO3s
