Standard Audio Volume
oufc1976 Mar 24, 2014
  1. oufc1976
    oufc1976 Member
    237
    82
    Not a thread to discuss the various pros and cons of each audio upgrade option, but to discuss a specific observation I've made.
    Playing via any source but most obvious via iPod, there is a noticable increase in volume from 0 through to 25. But 25 to 35 seems to have a minimal affect.
    iPod volume set to max, input volume set to max and GALA is OFF.
    When you go from 25 upwards there appears to be a momentary increase in volume but then it drops off.
    I'm happy with the overall results from the standard system, but it feels like it's being stifled at the top end.
    Anyone else notice this?
  2. constvoid
    constvoid Active Member TFSI Owners Group Team Scuba Audi A3
    123
    29
    I value (what's left of) my hearing, so I doubt I'll ever go as high as 25, let alone anywhere near 35 (I have the Audi Sound system anyway). :sm4:
    It may well be that there's a limiter in there somewhere, though.
  3. deolanp
    deolanp Member
    46
    OT-but Seriously i havent got a straight foward answer on the Bass from the audio system.Standard vs Audi Sound System vs B&O?Especially the b&o id like to know about since that is what I went with.Does it have a strong low bass so that i wouldnt need to put it to 25 volume?
  4. Schizophonic
    Schizophonic Well-Known Member
    868
    437
    Back to the OP's question I've noticed something similar. I play all my music through my BT on my nexus 5 through Spotify. I have my music pretty loud for example volume 25. When there is an instrument it stays on pretty loud and then the base kicks in it turns itself down. It's like it's reached the max output volume and won't go any louder. It's like when you have a crazy old system and you turn it up its distorted and crackly. Well it's like the mmi is stopping itself from doing this.
    oufc1976 likes this.
  5. constvoid
    123
    29
    If you'll excuse the pun this sounds very much like a limiter is in place, as I said before. Probably the amp is designed to do that so that it doesn't go into self destruct, or at least heavy clipping/distortion if the output becomes too much for it.
  6. Anarch
    Anarch Member
    131
    29
    When I listen to radio the volume is usually at either 2 or 3... when I listen to music from my phone i usually go to around 5. Why on earth would you want to turn it up to 35 ?
  7. MA3RC
    MA3RC Well-Known Member TFSI Owners Group VCDS Map User Audi A3 Team Brill Red
    1,166
    772
    I noticed mine doing this with the volume going down automatically, as if it's stopping itself from blowing the speakers, I tend to play my fav tunes at around 25, no higher usually
  8. arad85
    arad85 Well-Known Member Team V6 Audi S5 Black Edition
    754
    260
    To feel the music... I can understand people not liking loud music, but good, loud music becomes visceral. I have the ASS - it goes loud but not visceral loud (where you feel the objects around you move). Some people get loud music, others do not.... one of the reasons I live in a detached house is to not annoy neighbours too much :)
    the_lecht_rocks likes this.
  9. madrussa
    madrussa Member
    80
    39
    You can adjust the bass and the sub output from the tone menu. You'll be able to pump up the bass a bit... most users have said the bass is a little lacking and most users on the B&O topics have suggested they've increased both bass and sub output. It's not going to be thumping like a decent sub with independent amp but enough to satisfy most people.
  10. oufc1976
    oufc1976 Member
    237
    82
    Yup, exactly as you describe. Makes sense that it doesn't want to blow the speakers, but that suggests to me that the speakers have been poorly matched to the modest internal amplifier.
  11. oufc1976
    oufc1976 Member
    237
    82
    My hearing must be damaged then because I'd barely hear anything at 2 or 3! :)
    But it's not that I consistently listen to music at 35, I was just testing what the system was capable of and made the observation.
    That said, the source material dramatically affects how much you have to crank it up. CD and Lossless are more than loud enough at 25, but I've noticed that reduced bitrate MP3s need an extra push from the amp.
  12. oufc1976
    oufc1976 Member
    237
    82
    Think I may have cracked it.
    I realised I had some of the same music on my SD that I had on my iPod. And when I played them I didn't have the issue.
    So I unplugged the iPod and discovered I had the "Sound Check" setting on.
    I was under the impression this only affected the headphone circuitry but I've done a couple of miles with it off and the issue seems to have gone.
    On the way home tonight it was so bad it was like someone was turning the volume up and down quickly.
    Fingers crossed it's sorted
  13. Schizophonic
    868
    437
    That's the sound limiter embedded in your ipod. If the music tries to surpass a limit your 'sound check' setting will stop this. Like someone mentioned on this thread. It's the mmi internal amp that is stopping sound going through the speakers at a certain frequency.
  14. oufc1976
    oufc1976 Member
    237
    82
    I understand what the setting does on the iPod and assumed it had an affect. But you are right, as today I tested leaving the volume up at high levels and adjusting the bass. As the bass increases, the volume decreases. So it's definitely some soft of control from the amp.
    Just going to have to find a way to get used to it!
  15. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,937
    1,701
    I think that many mp3 players these days, possibly due to EU rules, have limits to prevent damge to your ears when using headphones...
  16. deolanp
    deolanp Member
    46
    Somebody should just try ptesting this with a song from the sd card with no possiblity of a 'limiter'....thenwe,l know if its the car or the ipod for sure
  17. Audi Toby
    Audi Toby 2016 S3 Saloon
    256
    51
    You can adjust the dB output of the system with VCDS by increments of 3dB I think, so in other words your current full volume (say 35) will then be 25 enabling you to turn it up further.
  18. oufc1976
    oufc1976 Member
    237
    82
    This is beginning to proper do my Swede in now.
    CD playback seems ok, but both SD and iPod show the same trait.
    Thing that's making me question it all again is that it's happening and normal volume levels too, it's just harder to pick out
  19. Audi Toby
    256
    51
    On my A4 the radio has completely different eq and volume settings to either of my media sources, could it be that simple? If not I'd say it was down to your source music files.
  20. oufc1976
    oufc1976 Member
    237
    82
    Might just turn it all off!
  21. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    99% sure the settings are universal and (edit: NOT) media specific.
    Agree with constvoid as never had volume that high. Volume 17 once was as loud as I could bear.
    John.
  22. oufc1976
    oufc1976 Member
    237
    82
    Even the wife noticed it today at normal volumes. It's as if the GALA control is knackered
  23. arad85
    754
    260
    Not sure what you are saying here, but I think different inputs have different tone settings....
  24. JohnM100
    952
    394
    I was thinking exactly the opposite. ie they are universal settings regardless of source (at least on non-tech pack)
    Curious who is right - that's the beauty of a forum ;-)
    John.
  25. Scott
    Scott Well-Known Member
    1,306
    126
    Can't believe some people listen to music on 2-3 or 5 max?
    I listen to the B&O at 45 (max is 49) sometimes :haha:
    Audi Toby likes this.
  26. Audi Toby
    256
    51
  27. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,687
    526
    Tone settings are individual to the media source. Or at least, they are on my tech pack with B&O.
  28. oufc1976
    oufc1976 Member
    237
    82
    Some of the 'tone' settings are unique.
    So for the standard system, Bass and Treble are per source.
    But fade and GALA are the same across all sources. Which makes sense.
    Can't comment on ASS or B&O but the standard system highlights poor recordings and bitrates.
    I've tested a number of formats on iPod, SD Card and the CD player itself, and lossless via iPod is clearly the best sound...even better than CD which suggests a fairly mediocre CD transport is fitted.
    The upside of CD playback though is that it doesn't appear to suffer from this volume issue I have. Although that could just be that the CDs I've tested to date aren't putting strain on the amp
  29. oufc1976
    oufc1976 Member
    237
    82
    To sum it up though...it's bloody fickle!
  30. Audi Toby
    256
    51
    Have you plugged it into VCDS?
  31. oufc1976
    oufc1976 Member
    237
    82
    Company car so I assume I can't do that without causing myself a world of grief?
  32. Audi Toby
    256
    51
    Only going to suggest getting it read with VCDS for fault codes in the Radio and Sound System modules as this will shop up more than just a generic fault code finder will, up to you mate.
  33. oufc1976
    oufc1976 Member
    237
    82
    Fair shout. Is there a thread on here that explains how to do it and what kit you need because I know squat about VCDS
  34. Flibble
    Flibble Active Member Team Estoril
    544
    142
    43
    There's a whole VCDS forum: VCDS (formerly VAG-COM) forum
    Genuine cables are fairly pricey though, at around £250, so you may be better off finding someone with one near you.
  35. Audi Toby
    256
    51
  36. Audi Toby
    256
    51
    More than likely you'll be better just finding somebody near you to do it.
  37. oufc1976
    oufc1976 Member
    237
    82
    Well, after putting up with this problem for a couple of weeks now, it has finally beat me in to submission.
    So, I've removed all non-lossless music from my iPod and turned the bass down and so long as I don't push the volume to the max, it's fairly stable.
    I checked retrofit prices and it's a non starter! (Been quoted £3k by one company just for ASS!)
    For my non-lossless music I will just put that on to an SD card, so I am forced to make a conscious decision on quality when changing source; the standard system is so transparent though that it makes most of it painful to listen to.
    The thing that bugs me most about this whole thing is that I originally specced the car with ASS, but was given a June delivery date. Got offered the option of the exact same car in two weeks if I dropped the ASS. A bit of a regret now. Although to be fair my car I had died 3 days before I picked up the Audi, so I probably made the right decision in that respect.
  38. Audi Toby
    256
    51
    Didn't realise it was down to your quality. Ive had so many problems with quality since I've changed the B&O, it really highlights bad music quality from the good! I will only ever use 320 Kbps in MP3 as it is a good compromise between quality and storage capacity. 44,000 kHz sample rate minimum.
  39. oufc1976
    oufc1976 Member
    237
    82
    Its not cured by sticking just to Lossless, but with a tweaking of the bass it at least becomes tolerable. And that's the best I can describe it...tolerable.
    It's easily the worst audio system I've ever had. Not because it's just plain bad, but because it's ridiculously fickle.
    My wifes standard set up in her new Corsa is better in so much that it's consistantly listenable and doesn't dictate to you how loud you should listen to your music.
    The Audi system tortures low bit rate music and runs for the hills when you dare turn the volume up.
  40. jakmorg
    jakmorg New Member
    13
    12
    Must be only on tech pack. My none tech pack has one universal tone setting regardless of source.
