Stage 3 remap instead of stage 2+
Haz1
Glasgow
Hi all
I have a situation due to the MTM remap. MTM don't make a stage 2+ remap like revo do so considering that I have a full turboback milltek exhaust and a uprated MTM panel filter, I was thinking of getting a autotech fuel pump. So if I install the autotech fuel pump and load the MTM stage 3 remap which is designed for the big turbo kit, which problems Im I likely to experience or would it work perfectly fine?
Haz
well you've kind of answered your own question. First of all your clutch wont last a day with Stage 2+ or 3. Your turbo wont be able to produce the required boost pressure causing failure with stage3. You also need a cold air induction kit, not panel filter. Intercooler is required of you want to make full use of a bigger turbo. And some use rs4/r8 injectors with stage3. Aw ye and you'l probably want some bigger brakes to stop all this power :)
I would look at getting a full intake system first to compliment your Milltek, such as the ITG (which i have) or the Forge,Evoms etc.
Massive difference !
Im definitely going to get a proper induction kit, thinking between the ITG and Forge Twintake, then thinking of the Autotech fuel pump. But with a stage 2 map only (not stage 2+) I reckon I wouldn't be getting the full benefit of the CAI and uprated fuel pump setup?
Imo your not getting the benefit of your exhaust at the moment because your still getting a standard air flow into the engine with the oem setup,when you fit a intake the volume of air the engine pulls in is massive (ITG has a 3'' internal bore pipe!! ) i seriously couldnt see how it would fit in the engine when i opened the box lol !
Ive done the opposite ive got the massive air flow going in and still have the restrictive exhaust causing back pressure.
The guys @ Star-performance said before i get the exhaust he recommended i got the fuel pump done first.
