Stage 2+ S3 low rev hesitation
Y444GAR Oct 31, 2010
  1. Y444GAR
    Y444GAR Member
    198
    Hi,
    I'm looking for some information regarding a slight hesitation that has just started with my 2010 S3. Car has done 11.5K. Mods on the car: ITG Intake, Autotech Fuel Pump, MV Sport Downpipe/Sports Cat, REVO Stage 2+. Car has had the mods since 2K miles and has run perfect up till now, the hesitation is lower down the revs with any kind of acceleration. (not clutch slip)
    If anyone has had any experience of this and knows what it could be could you pass on the information.
    Thanks in advance, Gary.
  2. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    Spark plugs? MAF sensor need cleaning?
  3. Y444GAR
    Y444GAR Member
    198
    I was hoping it was spark plugs. What do you guys recommend for uprated plugs?
  4. JamesS4cab
    1,191
    94
    I have some Platinum tipped ones. After I had stage 2 added.
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    ngk platinums oil flush and fresh oil should hopefully sort it out
  6. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    When you say hesitation, is it at idle, or as you pull away?
    I find my idle is a touch hesitant (even with new plugs) under cold start. Once she's warmed up she runs smooth as, but until then when the fuel is running rich there is a touch of inconsistency in the idle.
  7. Y444GAR
    Y444GAR Member
    198
    Its when your moving, my car is due an oil change. I changed the oil myself at 6k miles and its now counting down on my computer. Hopefully with the oil change and new plugs it should sort itself out. Thanks guys.
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    make sure and get it flushed to bud
  9. Brett Butler
    Brett Butler Member
    664
    13
    Can someone please explain to me why an oil change would help get rid of an engine hesitation?
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    it wont its just good practice to give the oil a can of flush to get rid of carbon buildup and fresh oil to keep it running smooth
  11. Y444GAR
    Y444GAR Member
    198
    I have replaced my plugs with NGK Iridium BKR7EIX. Car is now running perfect again.
  12. PH1L
    PH1L Gievf Buckets
    3,851
    40
    thought it would be sparkers ;)
  13. JamesS4cab
    1,191
    94
    Thank you and good night.:p
    On a serious note - its a massive releif when something simple and cheap cures a problem!! :music:
  14. Y444GAR
    Y444GAR Member
    198
    I know, was getting a little worried. Best £32 I have spent yet haha.
