Stacey's Belated Yo Yo Build Thread
StaceyS3 Feb 7, 2012
  1. StaceyS3
    StaceyS3 Well-Known Member
    2,502
    491
    Would love to be able to confidently TIG especially ally, have tig welded in the past during my apprenticeship but due to not needing to and lazyness I'd be very rusty and hoe through a lot of tungsten tips lol
    Did contemplate getting some stainless wire but will require getting another bottle of gas (££££) so if DP needs modding ill tack with normal steel wire and get a mate to do it on a tig set
    Car in its new resting spot till further notice ;)
    <tuffty/>, s3dave and Westy like this.
  2. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,829
    677
    TIG is surprisingly easy, a lot of it just comes down to tonnes of practice, all I do in work is pipe welding with tig, the pipe could be 25mm Wall thickness or 1mm, still use tig for all of it, all nuclear stuff so got to be nice and clean
  3. badger5
    9,472
    1,988
    she's allowing you to touch your car again?
    Sam_, jojo, StaceyS3 and 4 others like this.
  4. Westy
    Westy Well-Known Member
    17,443
    1,103
    Well it's not like she's going to let him touch her again ;)
    Gops, voorhees, s3dave and 4 others like this.
  5. StaceyS3
    2,502
    491
    Tig is without a doubt the nicer form of welding, it's definately all about hours practice playing with settings on the set but have to say I would also be very rusty with MMA and would be constantly getting the rod stuck to the work lol
    May have to buy a set one day and play a bit
  6. StaceyS3
    2,502
    491
    Haha.....I'm fixing things that need to be done like the gearbox as well as sorting a couple of other bits....if some parts like turbos, cams etc happen to mysteriously change then so be it ;)
    Westy and badger5 like this.
  7. StaceyS3
    2,502
    491
    Did a compression test with a slightly flat battery and it came out lower than I thought it would but at least was fairly consistent
    Pics in order cylinder 1-4
    Spark plugs in order 1-4, number one has quite a bit more of carbon deposited on it
    Sump plug had a bit of a build up on it
    Here is the state of play as was packing up due to darkness setting in
    Can anyone reconmend some plasti gauge to go for?
  8. <tuffty/>
    21,161
    3,838
    Could be your cams... have seen this before on wildish cams... artificially lowers comp ratio... can't remember what spec yours are..
    StaceyS3 likes this.
  9. StaceyS3
    2,502
    491
    True totally didn't think of that, cams are suspect for a lot of issues on this build, suppose if opening or closing to early or late would cause it
    Cams are currently catcams 3660 aka bobq purple grind, will be replaced with IECVA1's :)
  10. StaceyS3
    2,502
    491
    Plastigauge....
    Does anyone know off the top of their head roughly what the clearance is that am looking for on the bearings? (Will check ELSA later if not)
    This one does from 1-7 thou or 0.025-0.175mm in new talk lol
    http://bit.ly/IsqFRG
  11. Scullies
    Scullies Well-Known Member
    1,543
    657
  12. Scullies
    1,543
    657
    I tested my compression on a hot engine after about 1000km at all cylinders were around 160psi, I was pretty bummed.
    I recently did another test on a cold engine at the compression is around 190psi across all cylinders - happy days :)
  13. StaceyS3
    2,502
    491
    Cheers for the info and link mate ;)
    Stupidly I plastigauged the last engine as was a used crank but as everything was new in this I never bothered....fail lol
    Mine was as cold as can be when tested, had sat for 4 months without turning lol
  14. StaceyS3
    2,502
    491
    Got a little more done this afternoon
    Finished pulling the loom out and draining fluids, although was quite shocked and dissapointed at the state of the hard pipe and block
    Pretty much all that's left is the DP but I want to pull it with as much of it attached as possible as will weld some support brackets to it as if need to cut the flange off to reposition I know exactly the position of the dp for adjustments ;)
    Not much left with the subframe either as got another subframe and 2 driveshafts to go in, will also have to replace a track rod end as the nut picked up causing me to have to cut it off with the angle grinder
    State how I left it at the end of the day
    Can anyone reconmend tape to use on the loom as the insulation tape I used last time has just come off
  15. Lavis89
    1,829
    677
  16. Andrew@A.L.D
    3,877
    617
    Heat shrink the lot. But that means taking all of it out to do it.
  17. StaceyS3
    2,502
    491
    Cheers guys it's always worth an ask as so many **** products out there
    It has already been heat shrunk on some individual cores where has been spliced and may be able to get some 3-1 ratio heat shrink over some of the plugs but will have to go with tape for the rest ;)
  18. Broken Byzan
    13,237
    465
    Use 3m cloth tape. Oem type finish and loom is still conformable
  19. StaceyS3
    2,502
    491
    Cheers mate don't suppose you have a link as when searched on eBay I keep coming up with duck/gaffer tape?
  20. Broken Byzan
    13,237
    465
  21. StaceyS3
    2,502
    491
    Cheers mate will grab some :)
  22. StaceyS3
    2,502
    491
  23. Broken Byzan
    13,237
    465
    Generic product, for your power level etc, i'd get Meyle or Lemforder as they tend to be OEM +
    <tuffty/> likes this.
  24. badger5
    9,472
    1,988
    that hard pipe is nicked off another engine, as yours was perforated from corrosion...
    did you paint that block? let me know what paint so I know what to avoid - lol
  25. Dani_B19
    9,258
    379
    I've been looking at those track rods as well stacey, I emailed the seller to see what make they are and they replied with a company from doncaster that I've never heard of before.
  26. StaceyS3
    2,502
    491
    Cheers for the responses guys
    May just buy one decent track rod end to replace the knackered one then
    Just saw the set on eBay and thought about replacing the lot as they're all still the originals afaik
    Will name and shame the paint lol
    But iiirc you painted the pipe? Is g12 very corrosive as had a lovely coolant leak during its short life back on the road
  27. Sam_
    Sam_ Down under
    3,038
    480
    I got Meyle ones from ECS. Lemforder would be nice but mega money compared and my Meyle ones seem ok so far.
  28. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Whats power got to do with track rods.... :think:
    superkarl likes this.
  29. Prawn
    11,510
    3,425
    Car is more likely to be driven hard, and at higher speeds, so wear and tear is likely to be accelerated on this car, compared to an estate agents wife who uses her S3 to go shopping.
    Cheap product might last 5 years on miss daisys car and seem perfectly suitable, with Stace at the helm and regular abuse it might only last 6 months, so less acceptable :)
    simples :racer:
  30. s3dave
    10,110
    736
    Its a a threaded bar that wont know if its steering 500hp or 100 hp, track rod ends of course may see a bit more action..
  31. Prawn
    11,510
    3,425
    I was under the impression that we were talking about the ends, but the track rods themselves also have a ball and socket joint at the end, which will take just as much load as the track rod end I'd think.
    I know I'd certainly want only the highest quality joints at either end. OE track rods are SO expensive though!
  32. StaceyS3
    2,502
    491
    Can definately see the sense I'm buying a higher quality item with how hard will be pushed (although limited millage) but wasn't sure if "cheaper" brand ball joints were that poorer product?
    I only need to replace one end where had to cut it off after the nut picked up, but wondered if the set was a reasonable product would it be worth replacing the lot
    Been working on the mrs a bit more on the buckets and rollcage, I keep pointing out that it's the most sensible mod ever wanted to do as safety related
    but digging her heals in on this one is an understatement lol
    Maybe next winter will get fully stripped :(
  33. StaceyS3
    2,502
    491
    Oooo may have just bought a new (second hand turbo) :) :)
    Andrew@A.L.D and <tuffty/> like this.
  34. Andrew@A.L.D
    3,877
    617
    You got that one then? If so its a bargain
    Welcome to the GT35 family mate
  35. StaceyS3
    2,502
    491
    Maybe ;)
  36. Andrew@A.L.D
    3,877
    617
    Just had a look and its been sold :think:
  37. StaceyS3
    2,502
    491
    Not sure if I'd know anything about that ;)
  38. Andrew@A.L.D
    3,877
    617
    All hush hush then :whistle2:
  39. StaceyS3
    2,502
    491
    Not at all but will wait till it's actually mine in my possession.....then it's truly mine ;)
    Really shouldn't spend money when rather intoxicated lol
  40. Lewis583
    956
    91
    On the contrary Stace, sometimes the best things are bought after some drinks. Look at Prawn, he bought his CAE shifter while drunk and now he loves it haha.
    Looking forward to updates chap.
