Stacey's Belated Yo Yo Build Thread
StaceyS3 Feb 7, 2012
  1. StaceyS3
    StaceyS3 Well-Known Member
    2,489
    474
    Ahh spot on.....what a numpty lol
    Haven't tried them on the mani yet but the sleeves/spacers do come off and just turn them into the small port ones lol
    When I ordered them I just ordered the largeports as I knew some small port injectors you can't get to fit the largeport bungs (like my MTM ones) an worst case senario would turn a couple of fuel rail spacers
    Looks like worry solved
    Cheers :)
  2. StaceyS3
    2,489
    474
    Is a lot better with the spacer cups removed :)
    Although not completely happy with how far the o-ring sits in the fuel rail so may just take a couple of mm off of the mounts to make it sit lower?
    The injector nozzle position looks 100 times better (pics aren't to brilliant on the iPhone)
  3. StaceyS3
    2,489
    474
    I managed to dissapear for 20mins yesterday to the carpark and quickly whipped off my phenolic transition spacer to be ported for the new engine, am now running my small port mani direct onto my largeport head which isn't ideal but it'll do
    To my supprise the IE inlet mani runners are ever so slightly bigger than a largeport gasket, I roughed out the spacer with a carbide burr then bolted that and the gasket to the mani to port match it
    You can see where material has been removed off of the gasket, it only seemed to be the outer side of each port if working from the center of 2 & 3?
    I have removed the lip with a de-burrer as didn't want it to effect the seal
    Pics with the gaskets on after matching the other side to the head and a close up of the lovely porting which Andrew@A.L.D done
    Nice velocity stacks
    Still fits in the cupboard, although its getting tighter ;)
    Started to make a heatshield (utilising Prawns CAD techniques) to protect the rocker gasket and coil pack wiring by deflecting and channeling the hot air away
    Homemade bender using some plate and box section :)
    It will have some more trimmed off of it and some more bends
    Not sure whether to cut it down to just over the rocker gasket height or to try an bend it to shield the turbo and downpipe as had originally planned?
  4. Prawn
    11,418
    3,306
    looking very good indeed mate! Is the engine fully assembled now then? I had somehow missed that bit!
    Any ideas when it's all likely to find it's way into the car?
    As for the injectors, rather than machining down the rail, could you not use the spacers as intended on top of the injectors and space the rail up a few mm?
  5. StaceyS3
    2,489
    474
    Cheers mate :)
    All is pretty much assembled exept cams and belt as was waiting for cams and followers from the states
    Will all being well be putting the followers and cams in tommorrow (have been waiting for followers to soak in oil for a couple of days) my agn head should have been here by now but won't be till next week now so am waiting for the vvt unit and a spare rocker so can mod mine
    Once I'm pretty much done ill take it to my friend to do all the turbo lines, plan is to do as much as poss in hard lines near the turbo
    Then as far as I can think of its ready to go in which hopefully will be doing mid/end of march, which will allow me to make up the charge & Tip pipework, install and plumb the surge tank and then trailored to Bill when ready for downpipe and mapping :)
    The only thing which will dramatically change it all is if we are excepted for this house....waiting to find out today as its between us and another couple
  6. StaceyS3
    2,489
    474
    Well as much as I hate to say it I think the car will be put on hold with regards to anything that costs money.....as we have just had confirmation that we've been accepted for this house which is fcuking brilliant :)
    At least I can now have a man cave/workshop as has got a garage ;)
  7. Sam_
    Sam_ Down under
    3,035
    480
    Nice one! Couple of calendars from work and you're in business. Jealous mate.
    StaceyS3 likes this.
  8. superkarl
    superkarl MAN OF STEEL
    9,406
    2,379
    HOUSE PARRRRRTAYYYYYYY!
  9. Prawn
    11,418
    3,306
    I want a house :'(
    Congrats mate!
  10. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,124
    354
    Cracking news! This build with your own garage will be epic
  11. StaceyS3
    2,489
    474
    Cheers for the kind words guys am over the moon :)
    It only was advertised last wed as a part buy part rent with 25% starting share, viewed it on sat, which was narrow to 2 on Monday and we fcuking won
    Don't worry there will be a house warming party as soon as we get it before it gets decorated (is pretty disgusting and carpet is held down by duck tape in some areas, but at least wont have to worry lol) and shouldn't have to worry about neighbours to much as is detached ;)
  12. Westy
    Westy Well-Known Member
    17,443
    1,103
    You'll have no money left for the car now mate. My house is draining all my car funds :(
  13. StaceyS3
    2,489
    474
    It's a bonus I have bought pretty much everything now, the only big expenditures left are downpipe and mapping
    At least it will release funds selling the old engine and turbo kit ;)
  14. StaceyS3
    2,489
    474
    Managed to get a few bits done at work Saturday, although not as much as would have liked to, as had hoped for a quieter day but can't complain really ;)
    Like a muppet I spent a good couple of hours in the morning researching degreeing cams to find out they're preset and marked up lol
    Fitted the new lifters after having them soaking for a couple of days
    Had to turn a tapered sleeve to aid getting the camshaft seals on as would have had to force them on a bit possibly damaging them in the process
    Once had got the seals on I torqued up the cam pulley bolt and also the trigger wheel on the inlet cam, this required holding the cam firmly in a vice but used 2 thick blocks of plastic each side of it to not damage it as iirc the arp cam bolt has to be torqued to 55ftlb
    I managed to get the exhaust cam in but run out if time to finish off with the inlet and the timing
    I fitted the injectors with the injector spacers on the top and it now fits lovely with small fuel rail spacers, will see how it all lines up with how I want my breather system to be :)
    Goubo1 likes this.
  15. badger5
    9,405
    1,944
    nice progress Stacey
    those ports not so much ports as caverns :p
    this is going to be mental... :D one day
  16. <tuffty/>
    20,904
    3,713
    Check the bolts on the vernier cam sprockets (inlet iirc) for clearance on the VVT unit mate... had to 'machine' a little off the VVT on an engine Bill had in as the bolt heads contacted the VVT unit and undid themselves!
  17. Sam_
    Sam_ Down under
    3,035
    480
    Dude you're going to join Andrew's 'elite club' soon. How do you feel? ;)
  18. Westy
    17,443
    1,103
    Is that the skint club? ;)
  19. StaceyS3
    2,489
    474
    Cheers Bill really can't wait to hand it over to you :)
    Was thinking tthee other day am i going to need a new boost gauge as mine tops at 2 bar :racer:
  20. StaceyS3
    2,489
    474
    Cheers mate definately don't want that happening, will check when i get this AGN head in the next couple of days as iirc theres 2 slightly different casting shapes depending on age?
  21. StaceyS3
    2,489
    474
    What is this 'elite club'? The skint club as westy stated.....i'm without a doubt a member of that club ;)
  22. Sam_
    Sam_ Down under
    3,035
    480
    A guy with a Golf R here runs 42psi on his GTX30 ! Mental.
  23. Sam_
    Sam_ Down under
    3,035
    480
    His 'elite' 500bhp+ S3 club or something in his sig ;)
  24. <tuffty/>
    20,904
    3,713
    Stacey is already in the 'elite' club if it means the engine is in bits ;P
  25. StaceyS3
    2,489
    474
    That's mental! I'm pretty sure we won't be punching that high lol
    Should hopefully pass that magic number but will wait and see....time will tell ;)
  26. StaceyS3
    2,489
    474
    That's what it's all about...having the engine in bits
    Is it bad that this engine will probably be the third type of each engine component in this shell since I've owned it lol :)
  27. superkarl
    9,406
    2,379
    YESSSSSS, im part of a club :rockwoot:
  28. StaceyS3
    2,489
    474
    The engine may have to go in sooner than i thought :(
    Where i changed the coolant flange on saturday i rearanged the pipes that go to the rad as they seemed to be putting excess strain on the flange which could have caused the gsf on to fail in under a year?
    I must have forgot to put the hose clamp back on.....bloody muppet
    I was out for a "pleasure drive" after the gym and on the way home the coolant level warning came on, didnt think to much of it as have got used to keep topping it up due to the leak and just thought as its the first time its been up to temp since changing the flange an air lock must have cleared (also liquid was giving normal coolant temp readings)
    So drove home last mile or so to find once stopped there was steam coming out of the bonnet :sadlike:
    Popped the bonnet to find coolant all over the bay where the 3way hose to the rad had come off and it was boiling off of the head where it was rather hot
    Have topped the coolant up and fired it up and all sounds and seems ok except coolant temp was sitting around 105 degrees but assume thats just because everything was still pretty hot?
    Poor pic and cant really see a lot but here it is anyways
    Test will be tommorrow as will take it for a drive and see how it behaves?
    Hope have got away with it?
    Anything anyone can suggest can suggest to check or do?
  29. Andrew@A.L.D
    3,873
    609
    LOL i'm sure he will be in the elite club its also the skint club and in bits club
    I'm also starting a new club of bent a wrist pin club :banghead:
  30. Andrew@A.L.D
    3,873
    609
    Thanks Bill, I bet it will beat mine in peak power
  31. Andrew@A.L.D
    3,873
    609
    That reminds me i need to change my sig
    Job done
  32. StaceyS3
    2,489
    474
    Not to sure about that mate, although would love figures like that ;)
    Lol at all these clubs that are forming
    Just looked at your sig...haha brilliant
    Have been looking into arp studs the last couple of days as I've got oem ones in the new block
    Makes me also wonder if its worth trying to tac weld my trigger wheel bolts in situ?
  33. Andrew@A.L.D
    3,873
    609
    Main studs are on the cards and will be tig welding the bolts in place and the bolt for the oil pump
    nord locking the fluidampr in place now as they worked them selfs loose too
  34. Andrew@A.L.D
    3,873
    609
    And I've still got to get my 1600cc injectors ordered as I had to put them on hold, how wa the service from the place you got yours from?
  35. StaceyS3
    2,489
    474
    USRT were very good service, speak to Quintin on vortex is probably the easiest way :)
    Think I may try and put a welding blanket around the area and put a couple of squirts with the mig on the trigger wheel?
  36. Westy
    17,443
    1,103
    I think you boys are starting to stretch these engine WAY beyond what they're capable of. Might be time to start the Turbo'd 3.2 V6 club ;)
  37. Jason.s
    Jason.s Active Member
    2,879
    348
    You`re getting bad telling people what to mod next! lol. Think we need to start pressuring you into spending more money and time on the car again and not on wall paper and fabrics :whip:
  38. Westy
    17,443
    1,103
    Mate, you know where i'd rather spend my money! Unfortunately priorities change when you buy a house, as Stacey shall soon find out ;)
  39. badger5
    9,405
    1,944
    bent wrist pin? wow Tool Steel JE ones next?
    what cyl pressure was that running at I wonder?
    extra stroke loading do you think maybe? some acute rod angles on the big crank....
  40. StaceyS3
    2,489
    474
    To be honest I had wished 6 months or so ago that I had done a 3.2 but was in far to deep at that point ;)
    I'm sure we can try and keep pushing them but more and more weak points keep cropping up and you try to budget to start with but ends up turning to open cheque book trying to protect the investment and the inevitable happens
