Stacey's Belated Yo Yo Build Thread
StaceyS3 Feb 7, 2012
  1. StaceyS3
    StaceyS3 Well-Known Member
    2,492
    488
    Cheers mate..... think you've been watching the only is Essex to much lol ;)
    If was going to do it I would get it coated but don't think can warrant it at the mo :(
    But in doing so do you think it could raise egts to much? Will have to ask bill how James was on egt's
  2. StaceyS3
    2,492
    488
    Thanks mate :)
    Will have a butch when get a min, probably have seen it but looked at so many kits and parts now I don't know my arse from my elbow lol
  3. <tuffty/>
    21,016
    3,780
    EGT's should be ok... its more to protect the stuff around it... appreciate why you would be concerned about EGT's but tbh I doubt they will be an issue on the hardware you have... I haven't got much past 750 degrees (probe in DP remember) myself yet... and yours should be more efficient than my setup..
  4. Sam_
    Sam_ Down under
    3,037
    480
  5. badger5
    9,431
    1,975
    egt's were never an isue on james'
  6. StaceyS3
    2,492
    488
    Cheers for the replys guys....the seed has now been planted and am now seriously considering and looking into ceramic coating :)
    Have been looking around and can only seem to find 2 company's that do plasma ceramic coating which is the type which is more durable and handles the higher heat rating
    The obvious one being zircotec and woof is the other company which as far as can see use's the same process's but is apparently cheaper
    http://www.zircotec.com/page/home/1
    http://www.woof-tmt.com/what-is-it
    Anyone got any experiance or know much of these?
  7. badger5
    9,431
    1,975
    zircotec i use.. plasma sprayed zirconium - very good. their prices have risen a lot these past few years since I first started using them.
    not heard of woof-tmt myself tho
    shotblast the component and plasma spray the zirconium on it.
    my manifold/DP are zirconium flame sprayed. done years ago and still mint.
  8. StaceyS3
    2,492
    488
    Have emailed both for prices for mani, turbo, wastegate, and about 2.5 foot of 3' for downpipe as well as 1.5 foot of 1.75' for wastegate to downpipe?
    If I do go ahead bill would you be happy to send off the first part of the downpipe when you make it?
    Is there anywhere in particular that you buy your banjo fittings and stainless hard pipe from for the lines? Pressume I will need to buy a hand pipe bender?
  9. StaceyS3
    2,492
    488
    Forgot to say that woof does most of they're work for the oil industry and don't really do a lot on cars although they happily do so, it's not they're main area of interest
    He also said that the finish is a bit rough and recommended grey or black rather than white as gets quite dirty easily
  10. badger5
    9,431
    1,975
    the white zircotec is said by them to be the most durable to temps, and the coloured ones not so much. Whether this is the same for the other guys I dont know.
    it is rough finish.. sand paper abrasive.. hard as nails
    and yes it marks like a mofo..
  11. StaceyS3
    2,492
    488
    Have got quotes from both zircotec and woof, there's a reasonable amount difference between them price wise so will obviously go with the cheaper one which was woof, which turns out to be an old name or something as they must have been taken over and now be part of unisurf engineering as they're name on the quote is from unisurf but they call it woof thermal coating in the invoice
    I did speak to them on the phone and the process's and what the coating is rated to is the same specs as zircotec so seemed like a no brainer
    http://www.unisurf-eng.co.uk/?page=9
    I have fallen in love with the s3 all over again
    She had been neglected cosmetically for some time, I got her washed by the local car wash a couple of days ago which is the first time it's been cleaned since AITP all bar a quick jet wash as Bedford autodrome!
    A couple of pics including the new plate
  12. Sam_
    Sam_ Down under
    3,037
    480
    Does look really tidy :) like the 19s.
    StaceyS3 likes this.
  13. Prawn
    11,463
    3,356
    Always liked your car stacey, it's like all the others, apart from the bigger turbo, then you start looking over it and notice lots of other little bits that don't stand out at first, like the GC topmounts and other little bits that make the difference :)
  14. Westy
    Westy Well-Known Member
    17,443
    1,103
    Welcome to the S111 number plate club ;)
  15. StaceyS3
    2,492
    488
    Cheers for all the kind words guys really do appriciate it
    I should set myself another New Years resolution of making sure I keep it clean as makes me smile when I look at it again, it must have been without a soapy wash for 5 months or more lol
  16. StaceyS3
    2,492
    488
    Been looking at various cat cam offerings over the last few weeks and these are the few that i'm considering (although am leaning towards some more than others
    3651's
    3658's
    Bob Q Custom Grind
    This is if the IE ones aren't available before my shipment i am collecting together in the US is ready to be sent over
    Peoples thoughts and opinions?
  17. badger5
    9,431
    1,975
    what were the quotes stacey. please share.
  18. badger5
    9,431
    1,975
    bobq custom grinds... unknown spec surely? bobq has disappeared off the face of the tinterweb for some time now
    Catcams of my badgerwagen spec and of equivalent more "racey" style but will have lumpy idle but high top end gains.. for some low end losses... moved power up top where a larger frame turbo is working at its best remember..
  19. Prawn
    11,463
    3,356
    Just man up and get the 3658's Stacey :p
  20. Prawn
    11,463
    3,356
    are the above figures on a stock 1.8 or a 2.0 like your own? Remember that displacement increases 'tame' the effects of a lairy cam too, so the more lairy cam on the larger engine may well behave as well on the road as the less lairy cam on a 1.8, whilst still giving the top end gains.
  21. StaceyS3
    2,492
    488
    Not looking to go to lairy as don't want to loose to much low down....although I know it's always a trade off
    Had been mainly leaning towards the 3658's but the custom ones also look very nice and may be worth trying to keep some down the lower end of the scale even if have to sacrifice a little up top compared to some grinds...it's all a balancing act I suppose ;)
    Will email the quotes over when am home later
  22. StaceyS3
    2,492
    488
    Spec pulled straight off of the thread ;)
    Engine: 2008cc 1.8T
    AEB head- no porting
    Various CAT cams
    Hypertune intake mani
    70mm Mustang TB
    Pag Parts cast V-band mani
    Tial 38mm v-band wastegate
    GT3071R v-band turbo
    3" downpipe
    Magnaflow muffler
    Stand alone management
    Test done on Superflow 901 engine dyno
    Intake air temp controlled by large liquid/air intercooler
    93 octane pump gas
    Safe street tune
    20 psi
    Test pull from 2000 to 8000rpm
    20psi 93 octane pump gas with a safe street tune. 300RPM/sec
    You can see the point where the boost hits 20psi and the wastegate takes over where the curve flattens out at 3700rpm
  23. superkarl
    superkarl MAN OF STEEL
    9,430
    2,399
    i am sooo ****ing cool
  24. superkarl
    9,430
    2,399
    What you gonna rev to stacey??
    go 3658 if your gonna rev high
    thats a hell of a gain aswell for a 20psi tune.
    On vortex alot of the guys claim they regain the bottom end power through more timing, so all might not be lost.
  25. StaceyS3
    2,492
    488
    True true I'm sure bill will be able to perk it up with timing and will still be livelier than I'm used to down the bottom end of the rev range anyhows as will be going from 1825ish cc @ 8.5cr to 2008cc @ 9.5ish cr ;)
    Does seen like a very good gain on 20psi....hadn't really taken that into account
    Not sure how high will be revving? Suppose will be what bill and I feel comfortable with, what would you suggest bill? 8000?
  26. badger5
    9,431
    1,975
    will see how well the overall flow is and how the power peak is delivered.. but 8k is a reasonable guess.. my ibiza's 8800rpm limited but not peaked power !!
  27. Gizmo20VT
    Gizmo20VT Active Member
    294
    So much of win in this thread!!! <3
  28. burns3
    burns3 Member
    224
    17
    Couldn't agree more, the more i've read the better its got.
    Gonna be a bloody great car when its all done stacey, great work.
  29. Scullies
    Scullies Well-Known Member
    1,543
    657
    I got some 3658's in my 2.0 with precision 6262 turbo. Will see how they do when I get it running.
    There some 3652's on vw vortex up for grabs in the forced induction section.
  30. StaceyS3
    2,492
    488
    Like you say won't really know till the time although wont be like badger wagen? ;)
    Suppose a lot of the set up will be tailered for top end though with cams and .82ar housing?
    What do you reconmend on hydro's? some on vortex touching 9k but that sounds a bit to high?
    You get my emails?
  31. StaceyS3
    2,492
    488
    Cheers for the kind words guys it does help spur you on to do more ;)
  32. StaceyS3
    2,492
    488
    Yeah have been really scouring the vortex classifieds lately and had seen them but to be honest the 3652's i wouldn't wan't to be putting in my car as there is so much losses throughout the range and only seems to come alive until right up the top of the rev range
    The 3658's seem to be a really good combo which iirc is 3652 inlet cam and the smaller 3651 exhaust cam, didn't you end up with half a set of cat cams due to one being lost?
  33. Sam_
    Sam_ Down under
    3,037
    480
    The vortex classifieds are awesome aren't they. So many bargains to be had.
    Considered cams for mine but I think it'd be a waste on a puny GT2871.
  34. superkarl
    9,430
    2,399
    Have you upfraded the valvetrain stace i cant remember?
    8500 is said to be the safe max for uprated valves, springs etc. Which is pretty high. But like bill says it depends where power peaks and iif its worth it. What does the lcr bill did similar to this look like on a graph? I know it was impressive thats fo sho.
  35. Scullies
    1,543
    657
    I originally bought those 3652's but the guy messed up with the address and they didnt make it to me. He refunded me, I bought another set with an AEB head, then the inlet got lost, I got refunded by courier and bought the billet 58's :)
    My whole engine has been built from Vortex and Audizine deals :) - except block and pistons.
    I got a FSI crank for $80, some people just have no idea and its my duty to pray on the weak LOL
  36. StaceyS3
    2,492
    488
    Yeah am constantly scouring the classifieds now, especially now I've got the US repackaging account so can get loads of odds and ends sent there for reasonable cost then they sling it all in one package and send it over to me when I'm ready ;)
    I reckon you will definately see a benefit from a drop in inlet cam, they've seen pretty good gains with just the inlet cam as I think the stock exhaust is already pretty good :)
  37. StaceyS3
    2,492
    488
    Yeah have got ferrea valves and valve springs so should hopefully help to rev higher, iirc James Leon they revved to 7800 but don't hold me to that ;)
    If I manage to get on to my laptop later I will post up a plot of his car
  38. StaceyS3
    2,492
    488
    Bloody couriers! Sounds like you had a right nightmare, but at least got there in the end and reckon you've ended up with a lot better cam for it ;)
    I really wish I had bothered looking on vortex classifieds sooner as probably would have saved some doh and could have got some lovely kit, sounds like you've done very well out of it
  39. badger5
    9,431
    1,975
    stock stroke on badgerwagen, just larger bore
  40. StaceyS3
    2,492
    488
    Yours is a 83mm 1.9 iirc Bill?
    Little update as had some free time today ;)
    First off, turned a sleeve for the maf to bring it up to 4 inch, inline with the size of the tip
    Was a bit limited for materials but got creative
    Turned it down to size, bored it out, followed by pushing it on with the press (forgot to get pics)
    Finished Maf
    Then went onto the oil filter housing which was in a rather sorry looking state with loads of corrosion
    Cleaned as much up as possible with a rottary wire brush but still didn't look to good
    I eventually want to run oil pressure and oil temp gauges and there was only one spare port, so drilled and tapped another M10 fine thread into the other position
    I drilled right through to the center as this is from what i can make out after the cooler so will get more accurate temp reading there and after all the oem sensor goes through to the center where as the other spare bung goes through to the outer part of the filter
    Sprayed black as all i had in my cupboard and to hide the not so pretty bits
    Started to do the same with the cooler as also was in a bad way
