Stacey's Belated Yo Yo Build Thread
StaceyS3 Feb 7, 2012
  1. Sam_
    Sam_ Down under
    3,038
    480
    Top mount GT30 surely? or going Precision 6262 ;)
  2. StaceyS3
    StaceyS3 Well-Known Member
    2,502
    491
    Core won't be changing ;)
  3. StaceyS3
    2,502
    491
    That was a blinding weekend with some very haisy patches lol
    Keep forgetting how much we really got up to that night ;)
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would get that power steering pipe changed Stacey, a few Vauxhall Insignias have gone up in flames where the power steering pipe ruptured near the exhaust.... it was on watchdog a couple of week ago..
  5. StaceyS3
    2,502
    491
    Ohh not good :(
    Cheers for the info I will look and see if I can source one :)
    On another note things are going together smoothly even the downpipe as I ground down one of the flame rings so can actually slot it together now
    Well that was all smooth until I managed to slip with a 3/8 ratchet and hit my knuckles then causing me to drop the ratchet which fell and hit me in the mouth which has now given me a nice fat top lip......what a penis!
  6. StaceyS3
    2,502
    491
    Right decisions decisions?
    Top mount tubular v band manifold but unsure whether to wait until the end of june for it to have 1.5 inch pipe on the wastegate or get one a lot sooner with 1.25 but bill had a recent car suffer with boost creep and couldn't get the boost below 18psi
    Turbo housings... Atp are being helpful and i am going to change to a tial v band hotside as only $20 more than my one but not sure what ar to go for .63 or .82
    Comp cover i can now go to the full sized anti surge cover but is it worth it? Should just be able to exhange my one for it?
    Ideally want the car to be as responsive as possible which points to the .63 housing but is it worth doing if cant bring the boost in early due to surge?
    Opinions guys? :)
  7. Westy
    Westy Well-Known Member
    17,443
    1,103
    I say, take your time and get everything that's needed. If you know that another car suffered with a smaller wastegate pipe then wait and get the larger one.
  8. superkarl
    superkarl MAN OF STEEL
    9,463
    2,417
    maybe the smaller wastegate will be ok with .63? i dunno.
    this reallly is a yoyo thread lol.
  9. <tuffty/>
    21,138
    3,827
    Wait for the right mani mate... the boost creep was a mare...
    Tough call on the 0.63 vs 0.82... only really seen 0.63's on 1.8's with a GT30... Bill runs a 0.82 but on a much larger turbo so is inherently laggier...
    The LCR looks like this...
    The early spool is partially due to the extra capacity but the TSR runners are slightly smaller ID than the mani's Bill normally uses which will help spool too...
    The Tial hotsides look quite small compared to the Garrett cast jobbers but thats due to the process used (investment casting)...
    The GTX wheel you have is designed to flow more and spool quicker so maybe a 0.82 would be a better fit...
    As for the antisurge housing... the GT3076 on the TT still surged with one fitted so don't know if they are really that good... the smaller comp housing you have will make fitting easier for sure and surge can be mapped around at the end of the day... think about it realistically... surge is brought on by a certain volume of air not being able to flow at a given time... if mapped around the surge lines then you are no worse off than using a smaller turbo that doesn't surge as it can't produce the vol of air at the surge point of the bigger turbo (if you follow) so you aren't losing much other than a little torque from boost that could well be balanced out by adding ignition timing at that point...
    I would be tempted to run the current smaller housing for the time being, still run a 100mm TIP but reduce to 76mm for the turbo so if you really need to then you have the option... as for space... that will dictated by the fitment given with the manifold anyway... you can also (seeing as its a vband fitting) swivel the turbo round centering the housing in the gap you have so there is the same clearance either side... this way at least if you do have to for the larger comp housing you have given it enough room...
    Or just buy one anyway... ;)
  10. Andrew@A.L.D
    3,877
    617
    I'm on a 0.63 with my 2.1 and GTX3076r if that helps
  11. BENJAMIN
    BENJAMIN Active Member
    503
    93
    I'm running a T25 flanged GT3071R .82 housing. 18psi @4200rpm. 10psi around 3500rpm. Hope that helps!
  12. StaceyS3
    2,502
    491
    Cheers for the advice guys especially paul with your detailed essay as was a great help :icon_thumright:
    I read the whole thread for the lcr yesterday and it was on a .82 hotside iirc that is the main thing that has given me mixed thoughts although he does have more capacity being a stroker?
    Think i will wait on the mani to get the right one but the main problem is that from june through till the baby is due in sept i will be working nearly 7 12 hour days a week due to being holiday season and the overtime will need covering, so time to fit it all will be limited but think i should definately do it right :)
    Think i will give the ported housing a go as from what i understand from disscussions with atp i think i am going to be able to swap them as it was just an option when i bought it but if it does cost then will leave it and stay compact and be a test mule ;)
    I'am definately leaning towards the .63 ar especially as i now know you are running it Andrew but will make the decision over the weekend :)
  13. badger5
    9,469
    1,988
    thats too small a hotside for your spec. you have built a diesel in power delivery terms.. lol
  14. StaceyS3
    2,502
    491
    What size hotside in your opinion would you go with on mine bill? :)
  15. badger5
    9,469
    1,988
    0.6x as you are only normal cc
  16. Rosso TT
    Rosso TT Member
    146
    Sorry to highjack can some one post a link to the LCR thread?
    I like that power graph.
  17. Andrew@A.L.D
    3,877
    617
    seams to be ok for power delivery but i was to change how much would it cost?
  18. badger5
    9,469
    1,988
    its a balance/trade off between spool and flow ability
    2.1 its should spool nice enough to sacrifice a little for the top end flow benefit potential
    its what i would spec for a 2ltr with mods... especially yours being 2.1 and cams also mentioned?
  19. Andrew@A.L.D
    3,877
    617
    Piper cams are in the post and will get the housing swapped as i've had a look at my last dyno chart when it did 440bhp and you can see the short power band and were the power tails off
  20. badger5
    9,469
    1,988
    as a guide.. my ibiza.. 1900cc, stock crank, cams, largeport, SEM etc etc.... peak power is at my softcut limiter and climbing... which is what I would expect for yours also.. but yours would all start happening sooner than mine given its bigger displacement.
    I was looking at GTX35 comp maps only this morning, seeing what the GTX35 compared to the GT35 I ran before.. (closest to the actual Precision 62 comp wheel I actually run, which does'nt seem to have any published comp maps unfortunately) - Plotting the actual dyno results I have run so far on 12psi and 25psi, it sits pretty much on the centreline right of the middle.. and correlates very close to my 2 figures seen. More revs = more flow for same boost in my instance, so to find more power I would have to rev more... which I can do of course, or wind up the boost for the same revs and force more airflow thru. again, its a balancing act.
    turbo comp charts here are what I am looking at> Products | Turbochargers
    click the ones to compare... and see where your boost was and look for its lb/min flow... and as a guide.. 10lb of flow is 100bhp *ball park*
  21. Prawn
    11,496
    3,409
    Is where the suggestion that the ko4 hybrids can do 350bhp comes from Bill? as it has a 35lb compressor wheel?
  22. badger5
    9,469
    1,988
    yes.... exactly.
    and as we all know now.... or bloody well should do if they have been reading these hybrids threads for months and months..... lol, then just because the compressor can have this rating, everything else around it also has to be suitably sized for it
  23. StaceyS3
    2,502
    491
    Cheers think I will go ahead with the .63 ar and if I ever do fit a tfsi crank at a later date I can change it then ;)
    Iirc mines quoted somewhere around 55lb/550bhp but will never hit that figure and can't imagine 500 is possible on my set up with this turbo
  24. Prawn
    11,496
    3,409
    I wonder if I could be the first person to get a ko4 hybrid to reach 350bhp?
    And if I was, I wonder how long it'd last for! haha.
  25. StaceyS3
    2,502
    491
    I think it is possible mate with meth and a ****e load of timing but engine would self destruct if it should fail ;)
    Aem do a failsafe that monitors flow and if flow is to high or low due to a leak or blockage its got a output to drop boost or something else desired
    There's a seat Leon tuned by 0-400 that put out 650bhp (dyno lottery) on my turbo which is rated to 550 but was running 2.4 bar boost and lots of WMi at a strong mixture with a shed load of timing, but get the feeling it would spit bits of the engine to the moon and back at the first sign of a fault lol :)
  26. StaceyS3
    2,502
    491
    Well it's all up and running all ok after having to get hold of some more high heat steel heat sheilded pipe for one of the turbo coolant lines as the current length broke up on removal, exhaust also sounds better with no blowing noticeable as put all new gaskets in as well as some sealant :)
    So far downpipe doesn't seem to be fouling on power steering pipe any more as took it for a little drive and so far so good but couldn't really chuck it round a left hander to hard as got my tool chest in the boot till I return to work and it weighs a tonne and didn't want to damage anything
    Will probably give it a good thrash tommorrow night and find out if it's still good when really giving it some beans ;)
  27. Westy
    17,443
    1,103
    What exhaust sealant did you use mate? I've been using fire gum but not too sure how good it is. Also did you use sealant between the turbo to DP gasket as I'll be fitting a new gasket soon.
  28. StaceyS3
    2,502
    491
    I used it on both sides of each gasket and v band to be sure :)
    It was some stuff that tuffty recommended on a prior post earlier on during the week, it was a bit smokey when first started as expected because can't find any sealants that are rated above 300 or so degrees ;)
    While try and see if I can find the post no
  29. StaceyS3
    2,502
    491
  30. Westy
    17,443
    1,103
    I'll use what I've got as I've got a whole tube of it at the moment.
    Did you use anything in between the cat/decat to cat back exhaust system?
  31. StaceyS3
    2,502
    491
    Didn't as mine is all one piece from engine side of the steering rack to the cat back but if i was going to be taking that end of it all apart i would do :)
    I know bill uses similar sealant regularly
  32. Prawn
    11,496
    3,409
    I've been using the high temp silicon instead of gun gum lately on Tuftys recommendation, and I've found it's cleaner, looks nicer, and seems to seal up better for me as well :)
  33. StaceyS3
    2,502
    491
    Today I've noticed I'm getting a bit of heat on my left lower leg when thrashing it?
    I think have only noticed it today as am wearing shorts but pressume the heat is downpipe related?
    Anyone else had simular issues? I had heard of someone else that had a simular thing think it was Hollie with the TT?
  34. Westy
    17,443
    1,103
    That must be some serious heat to get into the cabin!
  35. StaceyS3
    2,502
    491
    Yeah it felt like having the air blower on full heat on my leg briefly at times athough of coarse my blowers were off
    Gotta admit i did see a peak of 975 egts on my b road blast this morning :whistle2: :racer:
  36. Westy
    17,443
    1,103
    975 is good for you :faint:
    It might be worth your time getting under the car and checking for heat damage around the DP. If you can feel the heat in the car imagine how hot it is around the DP!
  37. badger5
    9,469
    1,988
    I doubt it... its got a lot of heatshielding....... way way more than you have and a DP which does'nt actually touch anything
  38. Sam_
    Sam_ Down under
    3,038
    480
    I get this on an OEM downpipe/turbo setup. I think it's called driving it like it's meant to be driven ;)
  39. Prawn
    11,496
    3,409
    I actually ran for 6 months without the main front tunnel heatshield. One of the most uncomfortable things imaginable.
    Tunnel used to get so hot it'd burn your leg!
  40. StaceyS3
    2,502
    491
    Wasn't on the new setup which i expect is heavily heat shielded ;)
    I'll see if i can find it but iirc she said there was something burning her legs?
