Squealing sound
dzankizakon Dec 30, 2013
  1. dzankizakon
    dzankizakon Member
    67
    10
    When I start the car in the morning, almost every day the car squeals for approx 30 to 60 seconds while it's moving. The sound appears to be coming from the back, but I'm not sure. Also, the brakes squeal when I brake during those 30-60 seconds when the car starts. I took the car to the garage and they checked the brakes and said the sound is gone. It was gone, for a couple of days, and then returned. I don't think it's just the brakes, because the sound is emitted when the car is going, without any braking at all. After 30-60 seconds, the squealing stops and returns only if I leave the car alone for a couple of hours.
    Here's the sound: https://soundcloud.com/dzankizakon/squeal-8v
    If anyone has any opinion on what could it be, please let me know. It's embarrassing, because the car is practically brand new (5 months old, 12000km) and it squeals in the morning worse than a 30 year old mini.
  2. Dylock
    Dylock Active Member
    269
    71
    I couldn't get the clip to work on my phone but I would say it's the brakes. Are you in the uk with all this wet weather? How long are your journeys? Even without applying the brakes there is still a little bit of contact. Try using the brakes really hard for a bit to clean them up.
  3. gneera
    gneera New Member
    10
    I've had the same problem with my 8P every once in a while, especially after driving the sandy roads. Try to go reverse 10km/h and brake a few times. Worked on me.
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,256
    355
    does it still make the noise if you start the car with the air conditioning/climate control turned off in the morning?
  5. dzankizakon
    dzankizakon Member
    67
    10
    Thanks a lot for all the replies, they are very useful. :)
    I also have another 8P driven by my wife (bought new 5 years ago) but it never had this squealing issue (or any other issue, actually). I have not tried to drive without a/c - will do. :)
  6. dzankizakon
    dzankizakon Member
    67
    10
    Just to report that the problem has been solved by Audi.. apparently there was a tiny bit of contact left upon releasing the brake (as it's s-tronic, you also have to press the brake in order to start the car) when the car was cold. Now the car is as quiet as a mouse again, in fact a neighbor jokingly said my car must be electric considering how quietly it moves around the street ;-) Thanks everyone!
