squealing power steering
fourcircle Oct 22, 2011
  1. fourcircle
    fourcircle nj
    944
    32
    This is one that's been going on for ages but I haven't worked it out. when my steering is at full lock I get squealing from some part of my PS system. I thought i'd cracked it when I changed my v belt tensioner and belt during the summer but it's still the same. it's worst when i've just started up from cold, suggesting the pump itself or belt are less forgiving when cold. At times I get a bit of squeal just turning half way, not even on full lock. that does tend to be when the car is cold though.
    any ideas anyone? And no, it's not a cat stuck in my undertray
    cheers
  2. quattrojames
    14,068
    585
    When you say 'cold', are you talking Finnish winter cold? Might just be cos the belts stiff then?
  3. fourcircle
    fourcircle nj
    944
    32
    no mate, could be 20 degrees and it will still squeal when on full lock
  4. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    Could be the alternator clutch pulley
  5. fourcircle
    fourcircle nj
    944
    32
    thanks mate. Is that a typical offender for this kind of noise? if/when I get etka 7.3 working i'll look the part number up and see if I can get access to it without removing the whole sodding front end.
  6. Stubie
    Stubie Member
    135
    Mine also does this , just mine seems to be when on full lock whatever the temp !
  7. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    sometimes, low power steering fluid is to blame,
  8. fourcircle
    fourcircle nj
    944
    32
    i'll double check the fluid but i'm pretty sure it's ok (famous last words :) )
  9. Stubie
    Stubie Member
    135
    When I bought the car (privately) the brake system warning light kept coming on , discovered the power steering reservoir was empty ! Filled it up and left the cap off and turned from lock to lock for a few minutes ! The squealing is still there but not quite as loud !!
  10. Rhencullen1989
    Rhencullen1989 190 S LINE QUATTRO
    97
    Does the serpentine belt flap around a lot when the engine is idling, this gives the impression that the tensioner is weak, but in most cases is due to the one way clutch in the alternator pulley.
    I replaced my pulley in august because the belt was moving around so much it was causing the tensioner to rumble when pulling away on low revs, new pulley from TPS (genuine audi) was £80, took an hour or so to fit as the alternator needs to come out and you need a special tool to remove the old (and very tight) pulley, new one in and as good as new. You can check the pulley by removing the belt tension, gripping the pulley in your hand and quickly jerk it clockwise and counter clockwise, it should grip one way and slip the other way, its not a free running slip, but you should get a fraction of a revolution out of the alternator.
  11. Z82
    Z82 Member
    454
    Mines been doing this recently but mine is only on full lock to right :-/
  12. fourcircle
    fourcircle nj
    944
    32
    I haven't noticed that about the belt flapping but then I haven't really been looking for that. I'll check today. Even if it's not flapping in an obvious way it sounds likely that it could be to blame. 80 quid... I hope that's it and it won't turn out to be one of those cases where I change everything in sight and turns out to be something silly :)
  13. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Squeaks in the pas will be air in the system. Best course of action is to drain the pas. Replace the fluid and then jack the front of the car up until both wheels off the ground. Then bleed the system by turning the steering wheel onto full lock both ways until the sound has gone. May take a while but will work.
