Squeaky Alternator Belt ?
Oddie Dec 26, 2012
  1. Oddie
    Oddie Member
    181
    15
    Morning all
    My 2.0 TDI has started making a bit of a squeaking noise. It is definitely a belt squeaking. I sprayed some WD40 on the alternator belt at the front of the engine bay and it made the noise go away straight away but the next morning the noise returned. Does the belt just need replacing or could it be bearings causing the noise ?
    Also, how difficult of a job is it to swap over the alternator belt ?
  2. AudiB7Jay
    AudiB7Jay Active Member Audi A4 S-line owners group Team Aruba Blue TDi saloon Manual
    448
    26
    Do you know how old the belt is? When was it last changed? Does it look like a browny colour compared to the normal black colour?
    It won't be the bearings, if its a new belt it could be over tight causing the squeaking, if its old its just the material hardening causing the friction on the wheels rubbing together as the material get harder causing the squeak. I would replace the belt will probably cost no more than £20 for the belt. And half hour to fit it.
  3. pburv
    pburv Well-Known Member Team Glacier Gold Supporter Audi S3 quattro saloon DSG
    5,188
    10,859
    Hi Oddie.It could possibly be your aircon pulley.They have a clutch type pulley assembly and are known to fail..As for replacing your alternator belt i assume you have to take the whole front off the car.I could be wrong about that tho..Sorry I can,t be much more helpfull :wacko:
  4. NHN
    29,509
    1,764
    One way to do belt, which may or may not be suitable for the B7, is to get a spanner on the anchor of the belt tensioner, push this to the side as such which then slackens the belt enough to remove, then refit new one, test for sound next morning, most I know are able to be changed without the need for front of, but dont quote me on every single car :)
