Squeaking Brakes - Help and advice please......
CHRIS555 Dec 28, 2010
  1. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    Hi - I have fairly new pads and discs all round but I now have an annoying squeal when the brake pedal is applied.
    What are the normal symptoms and remedies for this?
    It's really beginning to pi*s me off when pulling up at lights followed by this bloody noise!!
  2. quattrojames
    14,060
    583
    Is it more than just salt and crud on the pads?
    Did you put plenty of coppaslip on the back of the pads? And are they oem?
  3. Hightower
    Hightower Member
    148
    I have the same problem with mine as I changed all the pads and discs recently but either the squealing is reducing with use or I'm getting used to it, I didn't fit OEM stuff. The squealing can be caused by many factors including pad material, I think the higher the metallic content the noisier they can be.
    But it's nowhere near as bad as when I fitted some fast road spec mintex pads with black diamond grooved and drilled discs to a pug 309 gti I had years ago, no that sounded like a touring car when braking, they didn't last long before I changed the pads back to standard.
  4. CHRIS555
    1,970
    10
    Yes, non oem and Mintex!! They are goin in the bin!
  5. Hightower
    Hightower Member
    148
    Did you get them from Brakes International? as I got mine from there and they were non OEM discs and mintex pads.
    Have your front pads got a strange bracket on the outside pad (closest to wheel), I found I had to bend them out slightly so the pad retaining spring could locate under it, as when I first fitted them i found the spring was putting slight pressure on the pad via the bracket and the pad was slightly rubbing on the brake disk after taking your foot off the brake, since I did that the squealing has virtually stopped, infact today I only noticed it once.
  6. quattro tony
    quattro tony Member
    167
    I tend to find ferrodo pads are bad for squealing, we used to fit them at work and were getting so many come backs we decided to fit bosch pads, massive difference noticed, fitted oem pads too which seem to be fine most of the time.
  7. paul20v
    paul20v Audi fanatic
    1,113
    See its all strange as we pretty much fit ferodo pads on everything and dont have any back.
