Squeaking at crawling speeds
T.Will Apr 19, 2014
  1. T.Will
    T.Will Member
    41
    Finally purchased my A3 used on Monday (58 plate). Yesterday, I noticed whilst driving at crawling speed with the window down a squeaking sound coming from the driver side. Not sure if front or back wheel. It seems it's intermittent, as I tried to have some one listen whilst I crawled by and it took a couple of attempts before it squeaked.
    I haven't heard squeaking whilst braking or turning the steering wheel.
    Any ideas what it could be. A search on here came back with the possibility of wheel bearings could this be true for my case?
    I thought I'd go for a short drive around the block this morning to check if it only happens at slow speeds. There was no squeaking when I pulled away and not for the majority of the short drive. Only about a minute away from home there were 4 singular squeaks.
  2. Sayam
    Sayam Well-Known Member VCDS Map User
    2,703
    631
    wheel bearings dont squeak i would describe their noise as a rumble.
    just whip the wheel off and have a nosey, could just be **** built up somewhere on the breaking mechanism or possibly low pads?
  3. fangio
    fangio Well-Known Member
    1,472
    174
    It'll just be the brakes squeaking. Just touch the pedal while it's squeaking and I bet it goes off!
  4. S3 AEX
    S3 AEX Active Member
    747
    211
    43
    Cheap pads?
