sqs haldex controller
Colly Aug 15, 2012
  1. Colly
    Colly Member
    282
  2. <tuffty/>
    21,873
    4,201
    Designed for people running lots of power on non std ECU
    Pointless on a fairly std car... particularly on a road car as to be any use you will be in permanent AWD and that will give you the low speed dragging issues that people experience with dodgy pumps etc..
    I would waste your money on something else... :)
  3. <tuffty/>
    21,873
    4,201
    Have a read of this... I have considered the competition unit HPA do which is a differnt unit to the blue controller most people have used...
    The Audi TT Forum :: View topic - Haldex Gen 1 Competition controller by HPA?
    The competition unit keeps the haldex lock under bracking too so it acts more like a torsion set up than the blue that releases haldex lock as you lift off or brake..
  4. Colly
    Colly Member
    282
    Thanks tuffty I have been looking at the hpa haldex controller I just can't really afford the £650 would the sqs item not do the samething just a bit more crudely all I'm after full time 4wd if possible
  5. rhys1210
    rhys1210 Active Member Team Meteor Team V8 VCDS Map User Audi S5 quattro
    177
    26
    It would make the car 4WD all the time but you dash would light up like a christmas tree. As the abs and traction control are all inter wired.
  6. <tuffty/>
    21,873
    4,201
    The SQS is not a controller suitable for a fairly std road car IMO... if building a 500hp drag monster then maybe... I have nearly 400hp and 300ftlbs of torque and still on a std controller... I have not had a issue where the setup has been an issue... thats not to say it would not be improved by a blue or even the HPA controller but in terms of bang for buck its not high on the todo list at the moment...
    I prefer the idea of the HPA controller as this will bring it as close to torsion as it can be while still making all the elctronics happy with no flashing lights and a slew of fault codes...
  7. Colly
    Colly Member
    282
    As close to full to,e 4wd is what I want . I think I might have to go for the hpa one tho
    thanks Tuffty I want to sort the 4wd before I go for big power as its too front wheel drive at the mo
  8. Sam_
    Sam_ Down under
    3,038
    480
    The HPA is commonly known as the "Orange". They often pop up for sale on VWVortex (along with the Blues).
    I have a blue but couldn't tell you a back to back as I fitted it soon after buying the car.
  9. Colly
    Colly Member
    282
    Is that vw vortex.com? I'll have to join that then thanks Sam
  10. Sam_
    Sam_ Down under
    3,038
    480
    Yep that's the one. There's usually plenty of tasty bits on there (along with some ****e). I've got quite a few bits cheap from there. Recently some Ground Control top mounts for a third of the new price. $50 later for new rose joints and they're good as new.
  11. Colly
    Colly Member
    282
    Thanks I've joined it. Do you know what haldex controllers fit the 8l is the just the Mk1 TT, mk4 R32 and mk4 4 motions?
  12. Sam_
    Sam_ Down under
    3,038
    480
  13. Colly
    Colly Member
    282
  14. <tuffty/>
    21,873
    4,201
    What do you call big power?
  15. Colly
    Colly Member
    282
    Late 300's really
  16. <tuffty/>
    21,873
    4,201
    Gonna need to change your intercooler then...
  17. Colly
    Colly Member
    282
    Why what's wrong with the forge one?
  18. <tuffty/>
    21,873
    4,201
    Too small for big power... low 300's tops and even then there is pressure drop... been there and got the t-shirt bud...
  19. Prawn
    11,665
    3,665
    it's a load of **** :laugh:
  20. Colly
    Colly Member
    282
    Oh right might have to have a re think then. Can you not just run larger side piping to and from the cooler ?
  21. <tuffty/>
    21,873
    4,201
    Yeah but the cooler is small and the inlet are 51mm... trust me I have been there... welly cooler or AH Fabs v2 for big turbo power...
  22. Colly
    Colly Member
    282
    Ah right thanks are they good enough for a hybrid then?
  23. Prawn
    11,665
    3,665
    Not really mate, they're not much use for anything beyond a st2 ko4. I'd even question that really. standard S3 pipework is 60mm, so 51mm pipes on an 'uprated' part are just a joke.
  24. Colly
    Colly Member
    282
    Could you get round this by using wmi?
  25. <tuffty/>
    21,873
    4,201
    You are missing the point... it's not it's ability to cool it's the ability to flow thats the issue... wmi will make no difference... the forge fmic is no use for big power... there is a massive thread on suitable fmic's in the stickies and I have fully documented issues I had with small fmic's in my build thread...
  26. Colly
    Colly Member
    282
    Ah right thanks
  27. <tuffty/>
    21,873
    4,201
    Here is a plot of my early setup using a small intercooler.... the graph to look at is the boost (bottom right)... you can see the orange boost line spike (measured at the turbo) and the red line is manifold pressure... a decent FMIC will have the turbo pressure line follow the manifold one but of course be a little higher as there will always be a degree of pressure drop across the systems...
    Not got a print out of an 'after' but fitting the AH v2 sorted this problem
  28. Colly
    Colly Member
    282
    Thanks I remember reading this now it wasn't going to be a problem as I was wanting to stay sub 300 or hybrid at the most, it's only the last few weeks I've thought of going big turbo
  29. <tuffty/>
    21,873
    4,201
    Forge FMIC is fine for stage1/2 imo... its most certianly an imporvement of the SMICs... the AH v1 is similar to the Forge and performs in the same sorta way... but 51mm inlets when the rest of the pipework is 60mm is always a compromise and back when Forge was the only option then it was what it was...
    It will sell easily enough when you are ready to go to the next level...
