sqeaky steering wheel
maxlbrown Jan 15, 2007
  1. maxlbrown
    maxlbrown Deep Blue
    248
    Help im going mad
    The problem Love my A6 however it has developed an annoying squeak when i turn the steering wheel it appears to be a metal/rubber squeak so i suspect a dry seal some where near the top of the steering column I have had the top cover off and tried grease,wd40,and oil on the steering column (on what i can get to). this appears to have no affect i have lubed the column and joints i can get to. Am igoing to have strip the column.
    any one else had this problem.
    Max
  2. Ewok
    Ewok Member
    Mine has the same problem, I am living with it at the moment but advise from anyone on how to fix would be grand!
  3. maxlbrown
    maxlbrown Deep Blue
    248
    Spray wd40 or thicker oil directly behind the wheel between wheel and cowel. this has seemed to do the trick.
    Hope this helps else its sterring wheel off.
  4. yoyo
    yoyo New Member
    I changed my bottom suspension arms to day As they were squeaking like a Silver Cross pram,especially when you turned the s/wheel, it turned out to be one of the balljoints had seized solid & was squeaking when it was being forced around by the steering!
    All quiet now & no more stares of amazemebt from pedestrians at what sounded like a turkeybeing scalded !!
    Anyone want to buy some nd hand ear plugs ???:kiss:
  5. jamescolbeck
    jamescolbeck New Member
    hey, ive been watching this thread for a while now and i think i have a similar problem? YOYO: when you say it was the ball joints, what car to you have? ive got a 2001 2.7 biTurbo avant with sport pack and think its the same problem. when turning at low speeds there is resistance thro the steering wheel and makes a squeek/grind type noise? def not steering wheel more below, poss steering rack/joints.
    any help would be most appreciated!
  6. maxlbrown
    maxlbrown Deep Blue
    248
    UPdate
    The squeak returned as expected with wd40 so i got some spray grease. Look behind the sterring wheel there is a plastic disk type thing (dust cover) I sprayed a liberal amount of grease in there and hey presto all quiet now. My problem was nothing to do with Ball joints.
    Hope this helps some one.
  7. bebecheekymonkey
    bebecheekymonkey Member
    40
    Hey Max, Happy New Year! Mine has just started to squeek at the top of the steering wheel. Looks like its the same as yours. Will have to get some spray grease as WD40 doesnt do anything.
    Speak soon.
  8. bebecheekymonkey
    40
    As Max mentioned above, I used a little spray grease in between the dark plastic disc right behind the steering wheel and hey presto...the squeek has gone.
  9. matt_o121
    matt_o121 2.8Q
    84
    it may be the air bag slip ring you guys are lubing, cheap to replace for a lasting repair!
  10. bebecheekymonkey
    40
    Matt, Can you provide any instructions on how to replace this? Thanks.
