Springs.....?!?!
Jack_tdi Mar 29, 2013
  1. Jack_tdi
    Jack_tdi Member
    287
    12
    A couple of questions about suspension
    I have an a3 Quattro 2.0 tdi s line and as far as in aware the suspension is the same as an s3 (ie the after market parts are the same )
    Are s3 springs lower than sline?
    And is there an aftermarket kit that is just as comfortable a ride as s line?
  2. Persian
    Persian CEO Audi S3
    270
    21
    not the expert but as far as im aware
    A3 Sport 15mm lowered (stock)
    A3 S line 25mm lowered (stock)
    And the S3 is lower then the s line by i think another 10mm making it 35mm from stock.
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,010
    204
    The S-Line ride is quite stiff so as long as you stick with a good quality brand you shouldnt have any problems.
    Did you have a drop and budget in mind?
    Damian @ DPM Performance
  4. Jack_tdi
    Jack_tdi Member
    287
    12
    Something around 40 mm but if the s3 ones where low enough they would be cheaper to get (second hand) than any others.
    Iv seen a h and r cup kit I quite like the look of but a little expensive.
    What would you recommend for around 300 quid ?
  5. dRicKyy
    dRicKyy New Member
    I also would like to see if anyone have Eibach Pro-kit 30mm springs installed with normal ambition coils on?
  6. DPM
    5,010
    204
    To get a full 40mm on an Quattro S-Line you'd need to go for coilovers.
  7. Jack_tdi
    Jack_tdi Member
    287
    12
    Would s3 lowering springs drop it by?
  8. DPM
    5,010
    204
    About 10mm, maybe a little more.
    Damian @ DPM Performnace
  9. Jonni
    Jonni Active Member
    245
    39
    Damian what's the ride gunna be like on h&r -25mm springs ?
  10. DPM
    5,010
    204
    On the S3 8P?
    It will be a little stiffer as you're going lower but not a great deal different to the ride from the standard springs which are already fairly stiff.
  11. Jonni
    Jonni Active Member
    245
    39
    Yerh sorry on the s3 8p . so more or less the same ride quality but a little lower cheers damian
  12. DPM
    5,010
    204
    Pretty much yes but it would be a little stiffer.
  13. Jonni
    Jonni Active Member
    245
    39
    :thumbsup:
