[ QUOTE ]
1. JBS Autodesigns do a manifold for the GT28RS
2. Jabbasport do a manifold for the IHI (Im using this)
You can buy the manifold, and fitting kit (water pipes, .etc .etc) from jabba, and then source a VF-34 elsewhere. All that you need to do to the turbo is spin the comp housing round 180 degrees so it sits in the correct place. You can also source injectors (Bosch green 44cc) pretty cheap on ebay .etc. The hard part for the S3 is the downpipe... I dont believe anyone has an off the shelf pipe for 4wd cars just yet.
^ ^ RyanC!?
The IHI kits really are not expensive... The custom work, however, is! If you can get a DP without having it done you will save yourself hundreds and remap wise you can get that done for ~£600
Also consider you really must do something with the intercoolers as they are crap, and fit sports cats and exhaust system.
RIch
[/ QUOTE ]
Thanks alot rich, that has really cleared up a few things!
I'm going to get the cars breaks and suspension sorted out and then I think I might go for it.
I'll have to look into the options for a Down pipe more though. Any ideas?
