Spot of mayonnaise under the oil cap...
_G_ Feb 16, 2013
  1. _G_
    _G_ Active Member
    876
    She's a thirsty girl, 2.0 TFSI 8p2 S-Tronic. Was topping up 1 quart of oil after 800 miles and noticed some white gunk under the oil cap rim...
    Half of it was covered at least but it was not too thick...
    Is this a head gasket job? How much would that cost? I think it is pre-warning signs anyway. The car runs fine. Does not over heat. Idles fine etc. I have been driving about 50 motorway miles a day (5 days a week) and need it for work!!
    No visible leaks on any coolant hoses.
    Any advice as to what it may be, if its a common problem and the damage to the wallet?
    Many Thanks!
  2. Boon
    Boon Active Member
    441
    59
    Depends on how much 'mayo' there is, and also the temperatures of both ambient & engine...
    Could quite simply be condensation
  3. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    606
    34
    Is it on the dipstick? If it is will probably be head gasket, if not will probably be condensation, however 50 motorway miles should clear it.
  4. audicruiser
    audicruiser Audi Heaven
    1,865
    Normal for this time of year with these engines. A good hard run (non motorway as the engine isn't working hard then) in the country will clear it.
  5. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,269
    2,090
  6. _G_
    _G_ Active Member
    876
    cheers lads
    none on the dipstick and oil looks fine on the dip stick too i.e. not watery
    I cleaned it off... took it for a country road run and its all good so far.
    No coolant loss so hope it stays good.
  7. The Governor
    The Governor Active Member
    528
    75
    Not that I'm an oil officianado or anything, but I wonder if it would help putting a different oil in, like 5w20 as that will heat up more quickly...
  8. audicruiser
    1,865
    No! Stick with what it recommended. Changing the oil weight will lead to other issues!
