Sportback Rear LED's
stealth64 Nov 5, 2009
  1. stealth64
    stealth64 Member
    201
    Hi all,
    I am new to the boards so please be patient.
    I have notice a few members have retro fitted OEM rear LED's to there a3 sprtbacks and was hoping to find a link to the best place to buy and how to fit the parts, is this something someone can help me with?
    Thansk.
  2. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
  3. stealth64
    stealth64 Member
    201
  4. crypric23
    crypric23 Never satisfied
    586
  5. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    your best getting the lights direct from audi and the looms from kufatec
  6. stealth64
    stealth64 Member
    201
  7. crypric23
    586
    How much where they from Audi parts ?
  8. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    Yes, thats the one. There actually 4 looms, 2 for the exterior lights and 2 for the lights on the boot lid. Don't worry about the fitting instructions, it's almost plug&play. For the outer lights you just have to plug the looms.
    For the ones on the lid you'll have to remove the trim on the interior to gain access to the wires leading to the number plate lights. The loom from kufatec has an exta wire which hangs out of the rest. This wire will have to be connected to the wire from the numberplate lights. This is needed to power the LED.
    I'll try to find the instructions I found when I changed them on my car.
    L.E. Found it:
    ktc_b0caeefa88c91a4973b14373d4a15c2c.pdf - 591.3 Kb
    L.L.E. You also have to do some coding in order for the light to work properly. Here is what you have to do:
    Code:
    central electronics
    coding
    help with long coding
    Btye 9 to Dec = 0 - as the final brake light
    Byte 10 to Dec = 0 - Fog lamps as a taillight
    Byte 12 to Dec = 36 - dimming rear standlight
    Byte 19 Bit 2 Cold Diagnosis rear active - this must be activated
  9. stealth64
    stealth64 Member
    201
    No idea how to do this coding bit!
    is this still worth me attempting to do this with little to no experience?
  10. Johnny Bravo
    898
    69
    For the coding you need a VAGCOM interface. If you are the type with two left hands, than don't do it yourself. As I said before, you need to strip a wire's isolation in order to connect other two wires. If you don't do it right, you may end up breaking something.
  11. stealth64
    stealth64 Member
    201
    Cheers for all the help so far guys. But i am worried about starting the task then finding im out of my depth!
    are there any companies in or around the midlands/shropshire that would be familiar with fitting these?
    also anyone got any ideas on cost of the light clusters? im still waiting for audi parts to get back to me!
  12. fizz
    fizz Member
    264
    I have been quoted £186 in vat from Stoke audi on the forum which is a great price.
  13. stealth64
    stealth64 Member
    201
    yeah that sounds good!
    shrewsbury audi said that the existing lights would cost £300 to replace so the LED's would cost alot more, but they never come back with a price!
    just need to find someone to fit em now!
  14. mattandrew
    977
    21
    Ive fitted a few sets in the past PM me if interested, im Nr Buxton in Derbyshire
  15. jamessg1962
    jamessg1962 Member
    123
  16. Johnny Bravo
    898
    69
    That's wrong! For SB makes no difference if its RHD or LHD. If it was the 3 door than yes, they are different. For the SB both clusters have the same set of lights. The 3 door version has a fog light on the left and reverse light on the right side (LHD) and viceversa for RHD. This is because on the boot lid there is no light (except for the number plate) like there is at SB.
  17. stealth64
    stealth64 Member
    201
    After talking with someone at in the trade, they said i may not need to do the recoding bit as my a3 is a 2006?
    can anyone confirm?
  18. Johnny Bravo
    898
    69
    Nope! You still need to do the coding or your lights will look like this:
    You have to "tell" the computer that position lights are no longer the bulbs but the LEDs and the bulbs should be used only when breaking.
  19. crypric23
    586
    Matt is ya man. Don't waist your money and time with audi. Jump in your car have a run to matts.
  20. kool_bouy
    kool_bouy New Member
    29
    HI i am new hear was about to post same question. Got most info from here cheers all. Just one thing in my mind is how to do the programming. What tool/software do i need. And where can i get. Or is there anyone in Leicester who can do it. Cheers.
  21. stealth64
    stealth64 Member
    201
    I have ordered this from kufatec
    http://www.kufatec.de/shop/product_....html/XTCsid/039b846be587db86a0855050001ae985
    plug it in and it should upload the correct code for you.
  22. fizz
    fizz Member
    264
    ordered my lights from stoke audi today for £186 inc vat plus around £6 postage :)
  23. Johnny Bravo
    898
    69
    Total waste of money IMO. You really couldn't find someone with a vag-com to do the job? It takes no more than 2 minutes to do it.
  24. Staz
    6,206
    64
    Clever stuff that!
    There's a 'members with VCDS' thread in the VCDS forum for anyone who wants the coding done for this mod. I am doing someone's this weekend. Saves you 30 euro!
    :shrug: that was the right thread mate!
  25. kool_bouy
    29
    Ok so Garages with the service reset thing should be able to do that also ya?
    Staz would u come to leicester or would i have to come to u? If so where abouts r u and how much would u charge?
  26. Staz
    6,206
    64
  27. kool_bouy
    29
    Cheers mate now i will just order the adaptor for the lights from KUFATECH and the lights from either stoke or leicester audi. Then will keep update on this post. Cheers for all the help. Will keep u updated shortly. While we at it does anyone have an aftermarket exhaust on a 3.2? If yes which is the best to go for.
  28. fizz
    fizz Member
    264
    Check item 400085393006 on ebay, cheaper than kufatec, got mine from there and was shipped within minutes of paying. Postage was 6.50 eur
  29. fizz
    fizz Member
    264
    Id also appreciate it if some1 could find matt's original thread where he did the mod, as can't for the life of me locate it. Link above comes up as invalid. Not sure if its been deleted.
  30. Staz
    6,206
    64
    Which link? The one I posted?
  31. fizz
    fizz Member
    264
  32. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    did someone mention me ?
    yes id be willing to code it up for you.
  33. 1wheelonly
    2,385
    111
    staz,
    the link is invalid, it states to contact a mod, i now have. lol
  34. Staz
    6,206
    64
    :uhm: works fine for me!
    Can you see this post?
    http://www.audi-sport.net/vb/showpost.php?p=656355&postcount=278
    This is what it says:
  35. 1wheelonly
    2,385
    111
    no mate, this is what comes up.
    Invalid Thread specified. If you followed a valid link, please notify the administrator
  36. Staz
    6,206
    64
    Okay cheers. I guess the thread has been deleted by the original poster. I have always used the link from the stickies thread. I'll sort it tomorrow.
    Is there another thread about the sportback lights though?
  37. fizz
    fizz Member
    264
    I looked but couldnt find one with the drtails that that thread had mate.
  38. Staz
    6,206
    64
    Ok well as I said I'm doing a set of Sportback lights on Saturday so I may well create a now 'How To' thread while we do it.
    Unless someone can find a decent one that's on here already :search:
  39. stealth64
    stealth64 Member
    201
    I am also attempting to fit mine over the weekend!
    Hoping its gonna be a simple process, may pm you if i get stuck!?:sos:
  40. Staz
    6,206
    64
    It could be the other way around too! lol
