sportback 170 black smoke
stespe2006 Jan 8, 2014
  1. stespe2006
    stespe2006 New Member
    15
    so I brought a 56 plate sportback 170 that had previously been remapped according to previous owner to around 200bhp which I would agree has been done due to the amount tyres I'm having to change, way to much torque for the 2wd anyway each time I accelerate aggressively I get quite a lot of black smoke out the back which is obviously fuel as it's black, could this be due to the remap or is there anything I can check before getting the map rewritten,
    would a a dirty egr cause black smoke??
  2. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,209
    389
    You can have the soot mapped out, not much of a "sleeper" if it does that
  3. stespe2006
    15
    totally agree can also be embarrassing lol.. having the soot mapped does that just mean decreasing the amount of fuel?
  4. LEE69
    2,209
    389
    No idea sorry, just know it can be done.
  5. asalhan
    asalhan Member
    33
    It might have had a DPF delete.
  6. hollow
    hollow Well-Known Member
    1,404
    162
    poor mapping needs a better map ,a slight wisp of smoke on acceleration fine . just a poor map on the car .
  7. Sidhu88
    Sidhu88 Active Member
    808
    76
    You tried running on a better fuel? e.g. run on vpower diesel rather than normal diesel? A normal car might take 2 full tanks to full adjust to the fuel, your car may be mapped to run on higher cetane fuel. If this is the case and your running on normal diesel then here lies your problem.
  8. LEE69
    2,209
    389
    Any car with a knock sensor will adjust automatically, did you see the r-tech fuel test with V.B.H?
  9. Sidhu88
    808
    76
    Nope. linky? I've always heard/been told that the cars self learn function normally takes a while before fully adjusting to a higher/lower rated fuel.
  10. willz17
    willz17 Member
    271
    22
    Hi mate,
    before my current car, i had a seat leon fr pd170 engine.
    I also had this mapped at stage 2 with dpf delete.
    whilst at stage 2 this smoked quite alot only on hard acceleration and even more noticeable in 5th and 6th gears.
    I soon had my map tuned down to shark stage 1+ from what i remember miko explaining it to me as.
    after this stage 1+ map was loaded it was much better just a light haze of smoke appeared on hard acceleration but nothing if driven normal.
    so overall mate i think your car has had DPF removed and this is the part which is supposed to catch the soot.
    Hope this helps
    Will
  11. LEE69
    2,209
    389
  12. c_w
    c_w Well-Known Member
    1,163
    87
    I very much doubt a knock sensor plays any part in a TDI engine, since it's knocking every time it's "firing" as it's a diesel engine. Fueling and timing is all based on engine position and throttle surely.
  13. LEE69
    2,209
    389
    I'm on a learning curve with diesels so just assumed it would be the same as a petrol.
